Undo the plug underneath, 24mm socket from memory,
Drain oil
Refit plug
Undo same size plug on side of box,
Fill with oil untill its jus coming out of the fill hole
Replace the plug
I prefer to replace the copper / aluminium sealing washers at the same time
evil_si wrote:Undo the plug underneath, 24mm socket from memory, Drain oil Refit plug Undo same size plug on side of box, Fill with oil untill its jus coming out of the fill hole Replace the plug
Maybe add a drive to the list to make sure sediment in the gear box is suspended in the oil so when you drain it it comes out with the oil
I've always filled the W's from in the cabin through the hole in the tunnel sans gear stick. Put the oil container in a hot bucket of water so it's easier/faster to pour into a funnel / hose.
Good to have someone keeping a eye on your bung hole on the side so they can give you a heads up when it's full.
Ive filled one on the ground and lifted it in, you get a bit of a leak from the rear spline, but if you're quick, you only get a few drips, all gravy.
