Neutral Starter Switch (NSW) bypass - AE101
Post Reply
Surge
Post by Surge »
I'm in the process of putting a formerly automatic 20V 4AGE into an AE92 Liftback manual (probably similar to the one your grandmother owns...) and I'm seeking information about the automatic (park/neutral) starter by-pass - that is the thing that allows the car to start only when it's in park or neutral.
What I'm hoping to find out is that whether this "NSW" pin on the ECU needs to be:
- Bridged with STA (start signal, so 12v while cranking)
- Given 12v+ (IGN on)
- Or grounded?
If anyone could shed some light on this it would be great - information on the internet seems rather mixed....
whynot
Post by whynot »
I'm pretty sure it works without connecting it. Just bridge the starter wires on the gearbox switch so it starts and possibly select a gear for the ecu to think it's in then it should be all go.
themaleman
Re: Neutral Starter Switch (NSW) bypass - AE101
Post by themaleman »
dose anybody have the answer to the question above? thanks
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
Stu-
Post by Stu- »
Bridge at the auto connector on the gearbox - away you go
Project Thread
themaleman
Thanks for the reply. Thats not posible for me as its a manual loom. As the orignal post asks dose the nsw pin require constant power, power when starting or be grounded? Thanks
4agte ae92 Levin
a15 powered sj410
GDII
Post by GDII »
On an SW20 MR2 the gearbox switch (park and neutral) effectively bridges NSW and STA pins on the ECU. You'd think it would be the same on the AE101.
1990 SW20 MR2
Previous 1990 EE90 Corolla
Stu-
Post by Stu- »
Your right, it does do that, but its much simpler to join at the plug in the engine bay than get the ecu out from the dash etc.
Project Thread
themaleman
Thanks GDII just the anser i was after!
4agte ae92 Levin
a15 powered sj410
GDII
Post by GDII »
This diagram isn't the easiest to follow but it is for a Silvertop. It shows the A/T wiring for the NSW system.
http://qrgarage.ca/wp-content/uploads/2 ... iagram.jpg
1990 SW20 MR2
themaleman
Im gusing its the same, its for a bigport redtop 4age into a suzuki using manual loom with an auto ecu
GDII
Post by GDII »
It seems to follow the same wiring as the MR2 5SFE/3SGTE diagram I have which is more detailed and in English. I assume you'd need to add a wire to the NSW pin on the manual loom and splice it into the STA wire as you don't have the plug and wires for the auto box.
1990 SW20 MR2
themaleman
Last night we were having a play with it and put the nsw pin into the ecu plug. Is the sta wire coming out of the ecu? If so we wil simply conect the 2 at the ecu end
4agte ae92 Levin
a15 powered sj410
GDII
Post by GDII »
Take the lid off the ECU and look at what pin is the STA. It should be labeled on the circuit board next to the pins. Similar to this.
http://imagizer.imageshack.us/a/img849/ ... 4age20.png
The STA wire should be coming out of the ECU so if you have already put a wire on the NSW pin then connecting it to the STA wire near the ECU should work.
Just looking at how the circuit works. It appears that the NSW pin needs a 12v feed with the ignition switched to Start and STA also needs the same 12v feed from the same wire.
1990 SW20 MR2
themaleman
Ok so your saying sta and nsw both need 12v from another sorce? Thanks for your helr thus far! My dad and i have just put a 4age into ous suzuki sj410. The engine and loom (it was runing on a manual ecu but that had been submerged in water) came from another suzuki. So we are using an auto ecu for the same engine that i had lying around. The engine refuses to start so we are gona look at the wiring and firstly what is needed to use the auto ecu.. So it may be that i try and find a diagrame of what the ecu needs to run just the engine and we make our own up to make sure we have everything and all sensors in the right place
4agte ae92 Levin
a15 powered sj410
GDII
Post by GDII »
The STA wire gets it's 12v feed from the ignition barrel. (which should already be there) See the first diagram I linked. If you splice the new NSW wire you put in to the STA wire it should complete the circuit tricking the ECU into thinking it's in park or neutral. Then it should start if that is the only problem and the Auto ECU pins match the Manual loom.
When you say 'refuses to start' do you mean fire or crank? Not having owned and barely driven an Auto myself I am not sure what the park/neutral switch does to the ignition. I assume it stops the starter motor from cranking.
1990 SW20 MR2
themaleman
Thanks wil give that a try tonight! It cranks. Has spark. Has pressurised fuel in the fuel rail. Wont run tho. Getn new plugs today also. Im picking its sumthing electrial. Hopfuly its the netural switch!
4agte ae92 Levin
a15 powered sj410
GDII
Post by GDII »
Just reading your other post. I figured the NSW pin wouldn't help as that only stops the starter from cranking rather than the engine running. Sorry that didn't fix it.
1990 SW20 MR2
themaleman
I was wondering how it workd hahaha good 2 know! That would explain why it stil cranked b4 we bridged them! Hey thanks for your help on the mater anyway. It can be hard finding the ansers your looking for on google sumtimes but can always rely on good old toyspeed members!!
4agte ae92 Levin
a15 powered sj410
Post Reply
