Rebuilding Bilstein suspension
Mr Ree
Post by Mr Ree »
Hi guys.
I have TRD (bilstein) suspension in my JZA80, and have always had a clunk from the rear, which I presumed was the sway bar end links, but a while ago, I swapped in some standard bilsteins from an RZ, and the clunk was no longer there.
Now I have refitted the TRD shocks and the clunk is back so Im guessing they are either due for a rebuild, or the force they exert on the rear arms/sway bar is far more than the factory suspension, and this is causing the clunk.
Who has had their Bilsteins rebuilt in NZ, where did you take them to, and how much did it cost, please?
Thank you :)
wak thud gush!
Grrrrrrr!
Post by Grrrrrrr! »
Haven't used him yet (new struts from Mark were too cheap to bother with a rebuild) but http://www.bilsteinmotorsport.co.nz/ would probably be a good bet quality wise.
GDII
Post by GDII »
You should be able to pick up OEM Bilsteins for a good price off Mark.
Are you saying your TRD suspension has Bilstein shocks in them? Which are different to OEM struts?
1990 SW20 MR2
Previous 1990 EE90 Corolla
2jayzgte
Post by 2jayzgte »
GDII wrote:You should be able to pick up OEM Bilsteins for a good price off Mark.
The grey TRD Shocks for the Supra are made by Bilstein.
Reith I don't even know if they are rebuildable.I've never heard of anyone having to get them rebuilt and if you do keep us posted.
Mr Ree
Post by Mr Ree »
I already have a set of the standard Bilsteins that are matched to a far softer spring combo. From memory they are only $155 each to replace, but yes, the Grey TRD suspension has bilstein shocks and are valved alot firmer to suit the rediculously stiff springs they are matched to.
wak thud gush!
RobertC
Contact:
Post by RobertC »
you might have the exact specs already but if not
damping force at 0.3m/s of piston speed
Front shock absorber 4292/1029N Fixed rate Made by BILSTEIN
Rear shock absorber 2538/637N Fixed rate Made by BILSTEIN
Front Lowering Spring K=107.8N/mm
Rear Lowering Spring K=92.1N/mm
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
touge_ae101
Post by touge_ae101 »
Bilstein guy sounds interesting. have heard about him but never used them. he used to work for autolign and got trained in Germany etc for rebuilding bilsteins so will no doubt be a quality job.
alternatively autolign rebuild bilsteins through their sister company racelign. good job and turn around at a reasonable price. iirc price for rebuilding/revalving bilsteins was around $170 a shock which i think is reasonable.
Mr Ree
Post by Mr Ree »
RobertC wrote:you might have the exact specs already but if not
Are those for the TRD suspension, or the factory yellow Bilsteins, please? Also, what springs are those specs for, as I believe there were a couple of different options
Thank you for your input :)
wak thud gush!
RobertC
Contact:
Post by RobertC »
Those are for the TRD suspension kit.
Can't find any reference to different spring rate springs.
http://www.trdparts.jp/english/parts_sus-set.html
Distrb
Regular Poster
Contact:
Post by Distrb »
touge_ae101 wrote:alternatively autolign rebuild bilsteins through their sister company racelign. good job and turn around at a reasonable price. iirc price for rebuilding/revalving bilsteins was around $170 a shock which i think is reasonable.
this is what i did when i had bilsteins shortened and revalved. sorted it through Autolign in Petone.
Perhaps contact them and see what can be done. is entirely possible the ones you have arent serviceable.
Looonie
Contact:
Post by Looonie »
http://www.supraforums.com/forum/showth ... ion-thread
Pretty sure I can source you new HD series Bilsteins (as mentioned in that thread to be same as TRD ones) for about $250 each.
Would have to confirm with my supplier, if you're interested, flick me a PM.
Rumple dee pumple dee doo...
Mr Ree
Post by Mr Ree »
Thanks for the offer, do you know how much the HD version differ to the typical yellow bilsteins found in the RZ's?
wak thud gush!
2jayzgte
Post by 2jayzgte »
Mr Ree wrote:Thanks for the offer, do you know how much the HD version differ to the typical yellow bilsteins found in the RZ's?
Reith why not just send the TRD shock away to the Bilstein guy in Auks see what he say's.I'm sure it can't be that expensive.
That Supra forums article is a good one I've been sold on TRD suspension for years > that throw together aftermarket stuff.
Mr Ree
Post by Mr Ree »
TBH, I dont really fell like wasting money shipping them around the country to be looked at. Ill send some photos of them first, to see if they can/cant be rebulit and go from there.
I love the feel of them, and the car handles great (for a fat whale) I just cant help but think that the "clunk" would be nicer if it wasnt there lol
wak thud gush!
jbod
Post by jbod »
George stocks do a good job
Post by Dell'Orto »
Stocks do Koni, not Bilstein though
jbod
Post by jbod »
Correct tho I understand they have access to billstein parts. Is it a coilover being repaired here or a sealed gas shock?
Post by Dell'Orto »
I daresay they'd just outsource to Autolign
jbod
Post by jbod »
Most probably right! Procure the parts for the work. I thought they were quite good didnt charge for every last nut and bolt and the chap (who i forget his name now) was very helpful.
Mr Ree
Post by Mr Ree »
They arent an adjustable "coilover" as such, but are an adjustable platform system, with 3 grooves cut into the body of the shock, and a small circlip that sits in them that you can move up or down to adjust the height.
Im fairly certain they can be rebuilt, I will have to take a closer look in the weekend as its something I have never paid attention to in the past.
wak thud gush!
Post Reply
