1994 Hilux Surf timing light reset?
- jacobrjett
- Toyspeed Member
Changed the belt how do you turn the timing light off? Google said to turn reds on hold tripmeter down turn key off and on but didn't work. Cheers
Re: 1994 Hilux Surf timing light reset?
Key on to ACC (first position). Hold down trip button and turn key to ON at same time. All lights come on, continue holding trip button until timing belt light goes out. Does that not work?
- jacobrjett
- Toyspeed Member
Does not work on older models. Cheers
It is possibly old enough where you have to pull the dash out and change the screw location over in the back of the cluster.
- jacobrjett
- Toyspeed Member
For 10 seconds??
- jacobrjett
- Toyspeed Member
Sounds likely, it doesn't seem simple. Cheers
- jacobrjett
- Toyspeed Member
Dash pull seems likely thought id check with the know how first. Cheers
jacobrjett wrote:Dash pull seems likely thought id check with the know how first. Cheers
Is the odometer digital display,
or the old wheels that roll around with the numbers on them?
Digital will most likely be push button,
old style will be dash out.
- jacobrjett
- Toyspeed Member
Old style cheers
- Mr Revhead
- SECURITY!
- Contact:
94 Surf, pull the dash cluster out and swap the screw
