Portable Air Con unit in a vehicle questions
Postby sergei » Fri Jan 21, 2011 5:32 pm
Have you considered DIY rig the electric compressor from Prius (obviously get AC guy to do the lines and gas)?
Postby MrOizo » Fri Jan 21, 2011 6:42 pm
sergei wrote:Have you considered DIY rig the electric compressor from Prius (obviously get AC guy to do the lines and gas)?
I havent but thanks for that suggestion.
Looks like work is keen to do the swap with the South Island one which has all the luxuries including leather seats :o Just have to wait another month.
Who knows why it wasnt the othe way around originally. :?
MrOizo
Toyspeed Legend
Postby sark.inc » Sat Jan 22, 2011 12:18 am
This sounds like the best idea tbh, how ever do you know if it draws off the high voltage or the 12v system?
sark.inc
Postby h8wrxs » Sat Jan 22, 2011 2:10 am
t sounds like all these options are alot of work, why would it be so hard to reinstall the standard air con system, wudnt it be a straight bolt up?
seems like the obvious solution other than swapping for a different van
h8wrxs
Postby ee904age » Sat Jan 22, 2011 7:24 am
h8wrxs wrote:t sounds like all these options are alot of work, why would it be so hard to reinstall the standard air con system, wudnt it be a straight bolt up?
MrOizo wrote: Its the reason the compressor was removed - to fit another alternator.
Obviously the second alternator is in the a/c's old position.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby h8wrxs » Sat Jan 22, 2011 3:18 pm
ahh gotcha, i missed that bit
h8wrxs
Postby sergei » Sat Jan 22, 2011 3:57 pm
I did some research and it runs at 200-220V AC three phase. So not really an option unless you build an DC-DC with three phase drive system.
Anyway, most electric compressors run from some form of high voltage, simply because it is much more efficient, cheaper and safer to run a small motor @10-15A then @100-200A.
Here is something you might be interested in:
http://www.masterflux.com/products/sierra/
