sergei wrote:Have you considered DIY rig the electric compressor from Prius (obviously get AC guy to do the lines and gas)?
h8wrxs wrote:t sounds like all these options are alot of work, why would it be so hard to reinstall the standard air con system, wudnt it be a straight bolt up?
seems like the obvious solution other than swapping for a different van
MrOizo wrote: Its the reason the compressor was removed - to fit another alternator.
sark.inc wrote:sergei wrote:Have you considered DIY rig the electric compressor from Prius (obviously get AC guy to do the lines and gas)?
This sounds like the best idea tbh, how ever do you know if it draws off the high voltage or the 12v system?
Users browsing this forum: No registered users and 32 guests
