Beams 3sge vs Sr20det vs 3tgte
Postby Babz » Mon Nov 15, 2010 5:40 pm
Hey guys. Just wanted to know what your thoughts are on which engine i should implant into my 1982 Carina TA63. It will be used as a daily driver with trips to the tracks every now and then. I have trying to decide but just can not make up my mind. They all seem to have plus and minus.
Babz
Postby shihad » Mon Nov 15, 2010 5:42 pm
well if its daily driven keep it reliable so go 3tgte keep it simple.
getting bottled by the friendly Oamaru locals for not doing skids - Coupe Life
shihad
Postby Babz » Mon Nov 15, 2010 5:45 pm
But for the money involved in sourcing a 3tgte and getting it up to spec wouldnt i be better of transplanting a newer motor? I am wanting around the 250 wheel hp mark and all three can achieve this easily with a couple of upgrades.
Babz
Postby Babz » Mon Nov 15, 2010 5:47 pm
Is the 3sge beams motor any good? meaning will it perform just as good as a s13 sr20det?
Babz
Postby wde_bdy » Mon Nov 15, 2010 5:51 pm
Dollar for dollar results, put in the SR.
Callum
wde_bdy
Postby Babz » Mon Nov 15, 2010 5:55 pm
thats what i figured out but damn i love toyotas. Does anyone have experience with altezza beams 3sge being transplanted into old rwd toyotas? does it go good? appreciated any info that is given to make my decision.
Babz
Postby Quirky » Mon Nov 15, 2010 6:01 pm
Theres an AE86 with a 3sge Beams.
Its a track only car running 150kw atw.
Sounds pretty sweet.
Although an SR20det would be quicker, more reliable, and plenty of aftermarket support. Go for the SR.
Hello There
Quirky
Postby wde_bdy » Mon Nov 15, 2010 6:04 pm
If you prefer Toyota power I would actually go with the 3T-GTE, its a much cheaper fitment job as it bolts in and the money saved can be used for a rebuild with forged pistons.
Callum
wde_bdy
Postby shihad » Mon Nov 15, 2010 6:07 pm
depends on your budget i guess. sr better engine in everyway but they did come out with 3t turbos so thats what I would use.i reckon you could buy a 3t and rebuild it for the same price as buying an sr.
shihad
Postby YeMs » Mon Nov 15, 2010 6:10 pm
wde_bdy wrote:If you prefer Toyota power I would actually go with the 3T-GTE, its a much cheaper fitment job as it bolts in and the money saved can be used for a rebuild with forged pistons.
Callum
yeh but they are a dog - speaking from experience.
sr would be your best option by far. or a 4agze??
Your local Hybrid Elite tech
YeMs
Postby QikStarlie » Mon Nov 15, 2010 6:15 pm
4agte
QikStarlie
Postby strx7 » Mon Nov 15, 2010 6:36 pm
altezza motor and 6 speed + turbo and aftermarket ecu
Postby shihad » Mon Nov 15, 2010 7:02 pm
strx7 wrote:altezza motor and 6 speed + turbo and aftermarket ecu
defiantly the coolest but if the goal is 250hp at the wheels bit of an overkill and $$$
shihad
Postby Soiled » Mon Nov 15, 2010 7:21 pm
http://z4.invisionfree.com/lexusaltezza ... opic=10816
Will probably struggle to get the 250hp at the wheels you'd be aiming at, but they do sound pretty sweet at 8k in old cars.
Most are around 118-130rwkws in standard trim, but very reliable.
Soiled
Postby fuel » Mon Nov 15, 2010 7:23 pm
you wont get 250hp at the wheels with a Beams 3S-GE cheaply. After a set of quads and outboard injectors maybe, it'll probably be 180hp at best at the wheels with a decent intake and headers/exhaust.
LOUD NOISES!!!
fuel
Postby Dell'Orto » Mon Nov 15, 2010 7:37 pm
13B bridgey ;)
Postby Truenotch » Mon Nov 15, 2010 8:08 pm
Phil - there are a few standard Beams with G4's and quads that have pulled over 200HP in NZ... But 250 would take quite a bit more development.
Truenotch
Postby d1 mule » Mon Nov 15, 2010 8:23 pm
3ts are a step in the wrong direction.
and i dont like cross breeding
so beams and 6 speed
i have a mate with one in a ae85 with quads and a link G4 its 200 HP at the wheels and more than fast enough as a rack car let alone a street car.
or 4agte, cheap easy been done a million times before so there is heaps on info, mine makes 230whp and its pretty standard just ht18/t3 450cc injectors and a link. more than fast enough
d1 mule
Postby tsoob » Mon Nov 15, 2010 8:55 pm
1UZ and be done with it
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Bling » Mon Nov 15, 2010 9:01 pm
No room for a....?
