falsgraves auto dismantelers in chch had a 2jzgte and getrag for $3K with all the pedal, line fly etc etc.
buy ill say 3000 for box
1000-1500 clutch
4-500 flywheel
mod d shaft 300
300? pedal
DONE
d1 mule wrote:under 8K EASY!!!! you just have to look around!!!
1000-1500 clutch
4-500 flywheel
mod d shaft 300
300? pedal
DONE
the fallen303 wrote:if you ask aussies or drag racers, they don't seem to like them, but anyone else swears by them. got one in my mk3, fitting one to dads mk4, and will source one for the aristo when cash becomes available. there's a washer that fails in them, i'm not sure which one it is, but think matt dunn on here knows which.
for the mk4, try and find a remote shift one from a z30 or x90 or x100, as this will line up with your drive tunnel, where as the mk3 ones are rear mount, and don't sit far enough back, so need to cut the body. expect to pay more for the remote shift ones though.
should handle the power you're after easily enough, same as anything really, treat them well, and they'll work fine.
Si wrote:Check out 1JZ747, did a 10.17 using a (modified) A340e auto box.
The R154 has a problem with the 1st geat thrust washer if you start thrashing the box.
postfach wrote:Take your stock one to an engineering workshop and get them to make one out of EN39B like gmcrae did, then get it hardened. Should take plenty of punishment.
Py7h0n wrote:Then again any clutch to hold 400wkw reliably is not joing to be enjoyable to drive!
My ACT MAXX Extreme from the US exploded on a 434KW run (drive straps on the pressure plate went). I would recommend twin or better if you plan on going past 400KW.
Py7h0n wrote:should be - but not fun to drive
Dell'Orto wrote:Twin plates tend to be nicer than multi puck button clutches actually.
Dell'Orto wrote:. In my experience with 3 puck clutches though, they're a damn sight nastier than a twin plate.
