11 sec 1/4 mile
Postby d1 mule » Sun Oct 19, 2008 1:02 am
under 8K EASY!!!! you just have to look around!!!
falsgraves auto dismantelers in chch had a 2jzgte and getrag for $3K with all the pedal, line fly etc etc.
buy ill say 3000 for box
1000-1500 clutch
4-500 flywheel
mod d shaft 300
300? pedal
DONE 8)
d1 mule
Postby avinesh » Sun Oct 19, 2008 3:17 pm
d1 mule wrote:under 8K EASY!!!! you just have to look around!!!
1000-1500 clutch
4-500 flywheel
mod d shaft 300
300? pedal
DONE 8)
will be gettin it done as i dont have any tools or time as well :(
220.1 rwkw
jzz30 bpu soarer auto = 13.3 @ 171 km/h
jza80 supra = 11.7
jza80 apu supra manual = 400rwkw
avinesh
Postby Py7h0n » Mon Oct 20, 2008 7:13 am
Your biggest problem with 11's will be the transmission. Supra auto's are not the best, not by a long shot.
Py7h0n
Postby avinesh » Mon Oct 20, 2008 1:40 pm
what do you guys think of the r154 box is it ok for around 350-400rwkw
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby the fallen303 » Mon Oct 20, 2008 2:43 pm
if you ask aussies or drag racers, they don't seem to like them, but anyone else swears by them. got one in my mk3, fitting one to dads mk4, and will source one for the aristo when cash becomes available. there's a washer that fails in them, i'm not sure which one it is, but think matt dunn on here knows which.
for the mk4, try and find a remote shift one from a z30 or x90 or x100, as this will line up with your drive tunnel, where as the mk3 ones are rear mount, and don't sit far enough back, so need to cut the body. expect to pay more for the remote shift ones though.
should handle the power you're after easily enough, same as anything really, treat them well, and they'll work fine.
true house of JZ
Stay true to the origin
the fallen303
Postby avinesh » Mon Oct 20, 2008 5:01 pm
the fallen303 wrote:if you ask aussies or drag racers, they don't seem to like them, but anyone else swears by them. got one in my mk3, fitting one to dads mk4, and will source one for the aristo when cash becomes available. there's a washer that fails in them, i'm not sure which one it is, but think matt dunn on here knows which.
what kinda washer also heard of that
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby Si » Mon Oct 20, 2008 10:51 pm
Check out 1JZ747, did a 10.17 using a (modified) A340e auto box.
The R154 has a problem with the 1st geat thrust washer if you start thrashing the box.
Current: , '96 SubaruImpreza
Si
Postby avinesh » Mon Oct 20, 2008 10:54 pm
Si wrote:Check out 1JZ747, did a 10.17 using a (modified) A340e auto box.
if the washer is replaced with after market one does it fix the problem.....??
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby postfach » Mon Oct 20, 2008 11:00 pm
Take your stock one to an engineering workshop and get them to make one out of EN39B like gmcrae did, then get it hardened. Should take plenty of punishment.
postfach
Postby avinesh » Tue Oct 21, 2008 1:10 am
postfach wrote:Take your stock one to an engineering workshop and get them to make one out of EN39B like gmcrae did, then get it hardened. Should take plenty of punishment.
o ok the gear box has to come apart for this aye???
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby postfach » Tue Oct 21, 2008 9:17 am
yes
postfach
Postby Py7h0n » Tue Oct 21, 2008 11:03 am
Then again any clutch to hold 400wkw reliably is not joing to be enjoyable to drive!
My ACT MAXX Extreme from the US exploded on a 434KW run (drive straps on the pressure plate went). I would recommend twin or better if you plan on going past 400KW.
Py7h0n
Postby avinesh » Tue Oct 21, 2008 6:10 pm
Py7h0n wrote:Then again any clutch to hold 400wkw reliably is not joing to be enjoyable to drive!
Ok bought a hks twin plate today should be here in a weeks time is this good enough????
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby Py7h0n » Tue Oct 21, 2008 8:01 pm
should be - but not fun to drive :P
Py7h0n
Postby flygt4 » Tue Oct 21, 2008 8:40 pm
HKS twin plates are actually not too bad
couple of people i know have run them and they are reasonably smooth. quarter master and tiltons are the real bastards from what ive seen.
flygt4
Postby avinesh » Tue Oct 21, 2008 8:41 pm
Py7h0n wrote:should be - but not fun to drive :P
was told this clutch gd type or sumthing hks has come up with allows you to slip the clutch an drive normally like a normal clutch :P
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby Dell'Orto » Tue Oct 21, 2008 9:14 pm
Twin plates tend to be nicer than multi puck button clutches actually.
Postby matt dunn » Tue Oct 21, 2008 9:33 pm
Dell'Orto wrote:Twin plates tend to be nicer than multi puck button clutches actually.
Not in my experience.
My multi-puk button clutch drive and feels close to a road car clutch,
can drive it on and off the trailer etc etc easy as,
have never driven a car with a twin plate that would drive like that and last for any lenght of time.
Drive a race car with a twin plate on and off the trailer for a season and the clutch may not last the season.
Postby Dell'Orto » Tue Oct 21, 2008 9:46 pm
Hmm, true...I've not spent that long with multiplate clutches, so dunno what the long term would be like. In my experience with 3 puck clutches though, they're a damn sight nastier than a twin plate.
Postby touge rolla » Tue Oct 21, 2008 9:57 pm
Dell'Orto wrote:. In my experience with 3 puck clutches though, they're a damn sight nastier than a twin plate.
They're not that bad. Just carparks and reversing uphill is best avoided.
touge rolla
