rocker cover removal - any tips?
Postby TWSTD » Mon Jan 03, 2005 10:03 pm
Any tips re removal of 3sgte rocker cover? Will i need to replace the gasket (assuming there is one)?
Click here!
TWSTD
Postby Twolitre » Mon Jan 03, 2005 10:32 pm
On Gen 1 - 3 all you do is remove all the bolts and lift it straight off so I can't see how yours will be any different, you don't need to replace the gaskets but you probably should.
Twolitre
Postby CozmoNz » Mon Jan 03, 2005 11:15 pm
Twolitre wrote:On Gen 1 - 3 all you do is remove all the bolts and lift it straight off so I can't see how yours will be any different, you don't need to replace the gaskets but you probably should.
alot of things probbaly should be done, but dont get done :) if you like your engine, do it :) just for the fact of while its off, you do it!
Rayne For President!
CozmoNz
Postby kingcorolla » Mon Jan 03, 2005 11:43 pm
mate, i have removed many a rocker cover, and i have NEVER replaced a gasket, and never had leaks afterwards. Even 30 year old 3k's with factory seals, good as gold.
Just make sure you clean both sealing surfaces of oil with a rag before re-attachment, and bolts are done up securly.
piece of cake.
1983 Carina AA63 4age
kingcorolla
Postby Caveman » Tue Jan 04, 2005 12:43 am
In the end its only a piece of rubber. You don't need to replace it but if you want a flawless 100% reliable (:roll:) car relace it. There only about $10 from supercheap. Just keep the seal away from contact once its off i.e. don't rest it on the concrete like I did :oops:.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby 1598cc » Tue Jan 04, 2005 1:50 pm
kingcorolla wrote:mate, i have removed many a rocker cover, and i have NEVER replaced a gasket, and never had leaks afterwards. Even 30 year old 3k's with factory seals, good as gold.
piece of cake.
key point ^
also, make sure you dont *pince* the rocker cover seal, otherwise youll know about it 8)
1598cc
