Twolitre wrote:On Gen 1 - 3 all you do is remove all the bolts and lift it straight off so I can't see how yours will be any different, you don't need to replace the gaskets but you probably should.
kingcorolla wrote:mate, i have removed many a rocker cover, and i have NEVER replaced a gasket, and never had leaks afterwards. Even 30 year old 3k's with factory seals, good as gold.
Just make sure you clean both sealing surfaces of oil with a rag before re-attachment, and bolts are done up securly.
piece of cake.
