any macanics please
any macanics please
Postby CEvans » Tue Aug 16, 2005 6:18 pm
hey if ther is any mccanics who would be keen to suss out the strange noise i have when first taking off would be kool im in wellington and would give cash if need be.
CEvans
Postby rotorchiki69 » Tue Aug 16, 2005 6:23 pm
omg u penis lern to spl propily and and mabiy pepul kan hilp you
rotorchiki69
Postby CEvans » Tue Aug 16, 2005 6:32 pm
you mean to say that you dont shorten you r words funny ur perfect. :D :P
CEvans
Postby Ae92typeX » Tue Aug 16, 2005 6:54 pm
You could just drop by a local mechanics when they are not busy- any decent nice place will have a listen and give you an indication without charge, my mates used to do it heaps.
what does the noise sound like and approx where in the enginebay is it comming from?
mite have been the 'mccanics'...hmm, I feel like mc'd's now lol.
but yea, spelling means shit and people textise their words all the time. Can help get more replies though granted.
Ae92typeX
Postby crnkin » Tue Aug 16, 2005 6:55 pm
shes taking the piss num nuts you dont need a mechanic you need to show up to school more
deaf_homo "currrently yes"
crnkin
Postby Spannergal » Tue Aug 16, 2005 7:28 pm
i'd say you don't necessarily need a mechanic. people who know cars well can usually put forward suggestions.
might help to explain the noise
Spannergal
Postby CEvans » Tue Aug 16, 2005 7:36 pm
yeah the noise is a slight ticking when i first take off at low revs normally up hill and when i change from first to second , i dont think its cvs but it seems to be coming from in the engine bay around the bottom of the engine i think, the car is a 98 levin bzr 6 speed manual.
CEvans
Postby CAMB01 » Tue Aug 16, 2005 11:26 pm
Could be an exhaust leak
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby RedMist » Wed Aug 17, 2005 10:51 am
Run a big end.
Or the inner CV's.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby bad20v » Wed Aug 17, 2005 12:03 pm
CEvans wrote:yeah the noise is a slight ticking when i first take off at low revs normally up hill and when i change from first to second , i dont think its cvs but it seems to be coming from in the engine bay around the bottom of the engine i think, the car is a 98 levin bzr 6 speed manual.
Yeah dude, mine used to do the same thing. Check the rear engine mount or the small rubber exhaust mount that sits on the rear of the front subframe. Also, if you have the time check that all your front subframe bolts are done up properly. After I had my gearbox replaced, I noticed a clicking sound in that same area, and the subframe bolts were all a little loose. Make sure they are properly torqued up.
Proberly the best thing you can do is take it to a mechanic's and put it up on a hoist and check everything underneath it. I did that and found that alot of things weren't as tight as they were suppose to be and the exhaust mount was completely stuffed. I don't have any funny noise's now. :D
Thank-You.
bad20v
Postby quinny » Wed Aug 17, 2005 4:56 pm
time for new front and rear engine mounts for you. the rear one is a bastard to get out so i would advise making it someone else's problem!
currently beating - AE101 Sedan, blacktop/6spd, tein coilovers, braided lines, cup holder, and every other bloody thing possible.
quinny
Postby bad20v » Wed Aug 17, 2005 5:11 pm
quinny wrote:time for new front and rear engine mounts for you. the rear one is a bastard to get out so i would advise making it someone else's problem!
Yeah, dude. Im sure you have to drop the subframe to get it out. :?
Thank-You.
bad20v
Postby trdfxgt » Wed Aug 17, 2005 8:42 pm
pinking ????
trdfxgt
Postby quinny » Wed Aug 17, 2005 9:46 pm
Had to get my snake armed mechanic mate round to get it out. he managed to get it out with the subframe in place.
quinny
Postby Spannergal » Wed Aug 17, 2005 10:12 pm
trdfxgt wrote:pinking ????
i'd say you'd be in serious trouble if you had pinking on takeoff
Spannergal
Postby neo » Wed Aug 17, 2005 11:54 pm
the one time.<gasp? i took my corolla. <gasp> to band-camp....
the auto sparky phucked with it and it pinked so bad, <gasp> that it just made it around the basin, <gasp> which is lucky <gasp> cause the muppets workshop is just there..
So it it fixed yet, and where the hell is that flute she was playing with?
neo
Postby CEvans » Thu Aug 18, 2005 8:24 am
cheers dude will go get it sorted to today ,
CEvans
Postby CEvans » Fri Aug 19, 2005 1:07 pm
i have jaked up one side of the car and turned the front wheel back and fawd the clicking is coming from the front wheels mainly the drivers side could it be a problem with the lsd and if it is im in for some big $$$ a?
CEvans
Postby bad20v » Fri Aug 19, 2005 1:48 pm
CEvans wrote:i have jaked up one side of the car and turned the front wheel back and fawd the clicking is coming from the front wheels mainly the drivers side could it be a problem with the lsd and if it is im in for some big $$$ a?
Don't get too worried just yet. take it to a well known suspension place in your area, and get them to check it out for you. shouldn't cost you anything to do so. better than just guessing what it might be and stressing over it. :D
Thank-You.
bad20v
