CEvans wrote:yeah the noise is a slight ticking when i first take off at low revs normally up hill and when i change from first to second , i dont think its cvs but it seems to be coming from in the engine bay around the bottom of the engine i think, the car is a 98 levin bzr 6 speed manual.
quinny wrote:time for new front and rear engine mounts for you. the rear one is a bastard to get out so i would advise making it someone else's problem!
bad20v wrote:CEvans wrote:yeah the noise is a slight ticking when i first take off at low revs normally up hill and when i change from first to second , i dont think its cvs but it seems to be coming from in the engine bay around the bottom of the engine i think, the car is a 98 levin bzr 6 speed manual.
Yeah dude, mine used to do the same thing. Check the rear engine mount or the small rubber exhaust mount that sits on the rear of the front subframe. Also, if you have the time check that all your front subframe bolts are done up properly. After I had my gearbox replaced, I noticed a clicking sound in that same area, and the subframe bolts were all a little loose. Make sure they are properly torqued up.
Proberly the best thing you can do is take it to a mechanic's and put it up on a hoist and check everything underneath it. I did that and found that alot of things weren't as tight as they were suppose to be and the exhaust mount was completely stuffed. I don't have any funny noise's now.
CEvans wrote:i have jaked up one side of the car and turned the front wheel back and fawd the clicking is coming from the front wheels mainly the drivers side could it be a problem with the lsd and if it is im in for some big $$$ a?
