anyway of running dizzy instead of cas on 4agze
Postby escortman » Thu Feb 07, 2008 6:54 am
my cas is constantly leaking through he main seal before the sealed bearing iv replaced it 3 times and it stil keeps on leaking, iv got a dizzy and igniter in my spare parts and wondered if there was a way to run this on the ze ecu until i get link etc
4x4 toyota blizzard offroader
escortman
Postby Trls250s » Thu Feb 07, 2008 10:51 am
You can run a redtop/bluetop dizzy as a CAS as it has a crank angle sensor in it.
This is how the NA engines get there crank angle readings. I know many guys who modify normaly dizzy to coil setup and just make a plate that goes over the unit instead of that plastic cover so its smaller as well (good for putting 20v's in rwd's)
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby escortman » Thu Feb 07, 2008 6:12 pm
o ok but wat do i do about going from the coil backs to igniter?
escortman
Postby Bazda » Thu Feb 07, 2008 7:35 pm
maybe its leaking cos you got alot of crank pressure, which maens u need some better breathers on the rocket covers.
I had to put 2 inlet covers on my 4agte so I can vent the exhaust side pressure and it was fine after that, no more leaks.
Postby escortman » Thu Feb 07, 2008 7:47 pm
Bazda wrote:maybe its leaking cos you got alot of crank pressure, which maens u need some better breathers on the rocket covers.
o i neva thought about it, there is a whole lot of pressure coming out, il put one of my other breather cam covers on and go buy a oil catch can
escortman
Postby matt dunn » Thu Feb 07, 2008 9:04 pm
Trls250s wrote:You can run a redtop/bluetop dizzy as a CAS as it has a crank angle sensor in it.
Smallport only, as the other have different number of teeth in them,
4 pulse and 24 pulse, as opposed to 4AGZE, Smallport and 20V which are
1 pulse and 24 pulse.
Postby Lloyd » Thu Feb 07, 2008 9:12 pm
[quote="matt dunnSmallport only, as the other have different number of teeth in them,
1 pulse and 24 pulse.[/quote]
2/24 you mean for the later?
Postby matt dunn » Thu Feb 07, 2008 9:22 pm
HRT wrote:[quote="matt dunnSmallport only, as the other have different number of teeth in them,
2/24 you mean for the later?[/quote]
Nope dont think so,
But more correctly,
24 pulse, 1 pulse and 1 pulse,
as they have three outputs, the 4th wire being the common earth.
The early 4AGE's had 4 teeth on the top wheel in the dist, and the smallport and GZE have one tooth, but two sensors on it.
Postby Lloyd » Thu Feb 07, 2008 9:35 pm
Yeah, that sounds right. Getting the 20V dizzy going with a GZE coil and ECU setup was a matter of swapping 2 wires. Think you're right about the 2 pickups on the single pulse
Postby escortman » Thu Feb 07, 2008 9:45 pm
huh that confused me, but i do hav a smallport dizzy so if i need to run that how do i do it?
escortman
Postby matt dunn » Fri Feb 08, 2008 12:53 pm
escortman wrote:huh that confused me, but i do hav a smallport dizzy so if i need to run that how do i do it?
to run a smallport dist instead of a GZE cas, just plug it in and it works.
Postby escortman » Fri Feb 08, 2008 7:08 pm
o and wat about the coil packs? spark plugs how shud i set that up ?
escortman
Postby matt dunn » Fri Feb 08, 2008 9:09 pm
escortman wrote:o and wat about the coil packs? spark plugs how shud i set that up ?
If your GZE is all complete and running,
just remove the CAS and fit the dist,
plug in the 4 pin plug,
and dont worry about plugging anything into where the HT leads go on the dist,
leave your original coils leads and plugs as is.
Postby escortman » Fri Feb 08, 2008 9:41 pm
yeh its all running ok sweet cheers heaps for that man
iv added the 2nd breather cover after work seems to hav slowd the leak dramatically
escortman
Users browsing this forum: Bing [Bot] and 11 guests
