anyway of running dizzy instead of cas on 4agze
Postby escortman » Thu Feb 07, 2008 6:54 am
my cas is constantly leaking through he main seal before the sealed bearing iv replaced it 3 times and it stil keeps on leaking, iv got a dizzy and igniter in my spare parts and wondered if there was a way to run this on the ze ecu until i get link etc
4x4 toyota blizzard offroader
escortman
Postby Trls250s » Thu Feb 07, 2008 10:51 am
You can run a redtop/bluetop dizzy as a CAS as it has a crank angle sensor in it.
This is how the NA engines get there crank angle readings. I know many guys who modify normaly dizzy to coil setup and just make a plate that goes over the unit instead of that plastic cover so its smaller as well (good for putting 20v's in rwd's)
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby escortman » Thu Feb 07, 2008 6:12 pm
o ok but wat do i do about going from the coil backs to igniter?
escortman
Postby Bazda » Thu Feb 07, 2008 7:35 pm
maybe its leaking cos you got alot of crank pressure, which maens u need some better breathers on the rocket covers.
I had to put 2 inlet covers on my 4agte so I can vent the exhaust side pressure and it was fine after that, no more leaks.
Postby escortman » Thu Feb 07, 2008 7:47 pm
Bazda wrote:maybe its leaking cos you got alot of crank pressure, which maens u need some better breathers on the rocket covers.
o i neva thought about it, there is a whole lot of pressure coming out, il put one of my other breather cam covers on and go buy a oil catch can
escortman
Postby matt dunn » Thu Feb 07, 2008 9:04 pm
Trls250s wrote:You can run a redtop/bluetop dizzy as a CAS as it has a crank angle sensor in it.
Smallport only, as the other have different number of teeth in them,
4 pulse and 24 pulse, as opposed to 4AGZE, Smallport and 20V which are
1 pulse and 24 pulse.
Postby Lloyd » Thu Feb 07, 2008 9:12 pm
[quote="matt dunnSmallport only, as the other have different number of teeth in them,
1 pulse and 24 pulse.[/quote]
2/24 you mean for the later?
Postby matt dunn » Thu Feb 07, 2008 9:22 pm
HRT wrote:[quote="matt dunnSmallport only, as the other have different number of teeth in them,
2/24 you mean for the later?[/quote]
Nope dont think so,
But more correctly,
24 pulse, 1 pulse and 1 pulse,
as they have three outputs, the 4th wire being the common earth.
The early 4AGE's had 4 teeth on the top wheel in the dist, and the smallport and GZE have one tooth, but two sensors on it.
Postby Lloyd » Thu Feb 07, 2008 9:35 pm
Yeah, that sounds right. Getting the 20V dizzy going with a GZE coil and ECU setup was a matter of swapping 2 wires. Think you're right about the 2 pickups on the single pulse
Postby escortman » Thu Feb 07, 2008 9:45 pm
huh that confused me, but i do hav a smallport dizzy so if i need to run that how do i do it?
escortman
Postby matt dunn » Fri Feb 08, 2008 12:53 pm
escortman wrote:huh that confused me, but i do hav a smallport dizzy so if i need to run that how do i do it?
to run a smallport dist instead of a GZE cas, just plug it in and it works.
Postby escortman » Fri Feb 08, 2008 7:08 pm
o and wat about the coil packs? spark plugs how shud i set that up ?
escortman
Postby matt dunn » Fri Feb 08, 2008 9:09 pm
escortman wrote:o and wat about the coil packs? spark plugs how shud i set that up ?
If your GZE is all complete and running,
just remove the CAS and fit the dist,
plug in the 4 pin plug,
and dont worry about plugging anything into where the HT leads go on the dist,
leave your original coils leads and plugs as is.
Postby escortman » Fri Feb 08, 2008 9:41 pm
yeh its all running ok sweet cheers heaps for that man
iv added the 2nd breather cover after work seems to hav slowd the leak dramatically
escortman
