docTRD wrote:my 1jzgte loves it too, wicked stuff havent seen any problems on any of my friends cars either. and its cheaper than other 98.
docTRD wrote:hmm dont think so? my flatmates 4age marino still gets around 7.5L/100k with it and i get about 10L/100k with the 1j, so i think its fine aye
Py7h0n wrote:Only thing is you will make less power using it. To get the same power or more than regular 98 you need to ramp up the timing.
I've tried it on the dyno and saw about a 5% power drop using the same timing map.
One really good thing about it is knock resistance. Your stock ECU should up the timing and make use of it, giving you more power. To make best use of this reset your ECU and try and stick to it as a fuel.
ax_zino wrote:Just remember that ethanol has approx 60% of the energy content that petrol has, so you will end up losing some fuel economy. I rek 98's the way to go, but I would because I import the stuff.
johndoe1025 wrote:havnt had it on a dyno, but i reckon you can feel the difference in fuel aye, old owner ran it on 91![]()
i have also cranked the ignition timing to the point where it starts pinking at low revs high load, but OMG did it go hard. since retarded the timing a bit. but it LOVES advanced ignition timing, nowhere near as impressive now
Crampy wrote:johndoe1025 wrote:havnt had it on a dyno, but i reckon you can feel the difference in fuel aye, old owner ran it on 91![]()
Cranked as in what did you have it set to? I chucked some more timing into my BZ-G and it seemed to go better, but never confirmed properly.
Seen a few times on TS, that Blacktops go best with about 8 degrees advance, as opposed to the factory 10 degrees, as it pulls timing out of it. It's something I might check on the dyno once I get the motor in.
