Bio Fuel +2ZZGE
Bio Fuel +2ZZGE
Postby GTCRSHR » Mon Feb 09, 2009 8:46 am
Gull force 10 i think its called
yes or no ?
pro's cons ?
has any one used this and noticed any difference,
Nothing to see here ...
GTCRSHR
Postby kompressor » Mon Feb 09, 2009 9:56 am
My car loves it!
kompressor
Postby rodstr » Mon Feb 09, 2009 7:50 pm
thought japanese cars cant run on this stuff?
rodstr
gas
Postby docTRD » Mon Feb 09, 2009 8:08 pm
my 1jzgte loves it too, wicked stuff havent seen any problems on any of my friends cars either. and its cheaper than other 98.
Daily : st191 corona liftback mmm room
Project : Jzx90 mark2 Tourer V
--- wtd: corolla GT ae92 sedan ---
"Mum i knw its another wreck, i only got it so i can put the seats in the lounge" YEAH RIGHT
docTRD
Mo Joe
Re: gas
Postby Crampy » Mon Feb 09, 2009 8:33 pm
docTRD wrote:my 1jzgte loves it too, wicked stuff havent seen any problems on any of my friends cars either. and its cheaper than other 98.
Is it?
The car ends up using more fuel running on this stuff though aye?
Crampy
Postby docTRD » Mon Feb 09, 2009 8:45 pm
hmm dont think so? my flatmates 4age marino still gets around 7.5L/100k with it and i get about 10L/100k with the 1j, so i think its fine aye
docTRD
Mo Joe
Postby Crampy » Mon Feb 09, 2009 10:09 pm
docTRD wrote:hmm dont think so? my flatmates 4age marino still gets around 7.5L/100k with it and i get about 10L/100k with the 1j, so i think its fine aye
Mint, got a station down the road from me. Might try using it.
Crampy
Postby Emperor » Mon Feb 09, 2009 10:12 pm
There's a list on the either Gull or LTSA site regarding what cars can or cannot run it.
Subaru's are a no no.. Early Honda's are a no, but late model are..
Emperor
Postby Py7h0n » Tue Feb 10, 2009 4:39 pm
Only thing is you will make less power using it. To get the same power or more than regular 98 you need to ramp up the timing.
I've tried it on the dyno and saw about a 5% power drop using the same timing map.
One really good thing about it is knock resistance :). Your stock ECU should up the timing and make use of it, giving you more power. To make best use of this reset your ECU and try and stick to it as a fuel.
Py7h0n
Postby Crampy » Tue Feb 10, 2009 5:09 pm
Py7h0n wrote:Only thing is you will make less power using it. To get the same power or more than regular 98 you need to ramp up the timing.
So it should go well on a Blacktop then, seeing as they don't even really like the factory set timing with our poo fuels
Crampy
Postby johndoe1025 » Tue Feb 10, 2009 6:01 pm
i run only gull 98 force 10 in my blacktop
johndoe1025
Postby GTCRSHR » Wed Feb 11, 2009 10:39 am
johndoe1025 wrote:i run only gull 98 force 10 in my blacktop
have you had it on a dyno, any difference worth noteing
GTCRSHR
Ethanol
Postby ax_zino » Wed Feb 11, 2009 2:23 pm
Just remember that ethanol has approx 60% of the energy content that petrol has, so you will end up losing some fuel economy. I rek 98's the way to go, but I would because I import the stuff :D .
ax_zino
Re: Ethanol
Postby Crampy » Wed Feb 11, 2009 3:25 pm
ax_zino wrote:Just remember that ethanol has approx 60% of the energy content that petrol has, so you will end up losing some fuel economy. I rek 98's the way to go, but I would because I import the stuff :D .
Yeah, that's what I heard this why I asked if cars were using more when running on this stuff.
Still 7.5 litres per 100km in a Blacktop suits me just fine.
Crampy
Postby barryogen » Wed Feb 11, 2009 5:54 pm
if you do a search on similar topics with posts from me, you should find the reply I got from toyota NZ about it.
from memory it said something like the import 2zz don't use it, the NZnew 2zz is fine on it.
When I went back to them with matching part numbers for all the fuel components(tank, pump, fuel lines, fuel rail, injectors and a few other bits), they went silent.
barryogen
2ZZ Guru in training
Postby johndoe1025 » Wed Feb 11, 2009 8:46 pm
havnt had it on a dyno, but i reckon you can feel the difference in fuel aye, old owner ran it on 91 :( :evil: i have also cranked the ignition timing to the point where it starts pinking at low revs high load, but OMG did it go hard. since retarded the timing a bit. but it LOVES advanced ignition timing, nowhere near as impressive now
johndoe1025
Postby Crampy » Wed Feb 11, 2009 9:11 pm
johndoe1025 wrote:havnt had it on a dyno, but i reckon you can feel the difference in fuel aye, old owner ran it on 91 :( :evil: i have also cranked the ignition timing to the point where it starts pinking at low revs high load, but OMG did it go hard. since retarded the timing a bit. but it LOVES advanced ignition timing, nowhere near as impressive now
Cranked as in what did you have it set to? I chucked some more timing into my BZ-G and it seemed to go better, but never confirmed properly.
Seen a few times on TS, that Blacktops go best with about 8 degrees advance, as opposed to the factory 10 degrees, as it pulls timing out of it. It's something I might check on the dyno once I get the motor in.
Crampy
Postby GTCRSHR » Thu Feb 12, 2009 11:00 am
i had to put 91 in when coming back from whangarei as they didnt have 95,
i didnt notice a loss of power or fuel economy, didnt run any worse, no differnece at all,
i prefer to run it on 95 being "higher" octane,
i havent tried 98 or bio fuel hence the reason for asking
i am only getting about 450km out of a full tank and if bio fuel is going to give worse not a lot of point in changing
so if i was to put it in, and reset the ECU would it advance the timiing ?or am i thinking stupid :)
GTCRSHR
Postby johndoe1025 » Thu Feb 12, 2009 7:22 pm
i didnt have it specifically set to anything, i had just put my motor together and i ga`ve it an "ear tune" (advance it, rev, retard, rev, retard till it stops pinking, then retard a little bit more to be safe) we then bridged the ecu termianls to set it properly with a timing light, set it to 10 deg or whatever and it ran like absolute shit, power came in big surges, rough as, jerky, i was lyk wtf, im goin back to my ear tune! lol
johndoe1025
