How many k can ur 20v clutch cover b4 u need to change it?
Postby alastabesta » Wed Mar 10, 2004 10:44 pm
ok this is so unfair
i treated my clutch better than some of you and yet you guys can get 10 times more ks than me...
2001 Caldina GT-T
alastabesta
Postby rcook_nz » Thu Mar 11, 2004 5:51 pm
well if i oply got 100000kms id still be disapointed should last damn long if its look after u got serious problems to only get 10000kms
rcook_nz
Postby B1NZ » Thu Mar 11, 2004 5:51 pm
Sometimes if you let your clutch waer down too much or whatever aparrently it can wreck the flywheel where it grabs, i've been told to machine the wheel when replacing the clutch so it lasts longer??
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Monsterbishi » Thu Mar 11, 2004 7:20 pm
Loudtoy wrote:Well dude sounds like your not having a good time with clutches - i assume you let it bed in properly and everything?? Don't suppose you've tried bleeding the clutch system sometimes they can get air bubbles in them when you change clutches!
Air in the clutch system will cause it to not disengage properly, bleeding the clutch would not help his situation...
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby Monsterbishi » Thu Mar 11, 2004 7:24 pm
B1NZ wrote:Sometimes if you let your clutch waer down too much or whatever aparrently it can wreck the flywheel where it grabs, i've been told to machine the wheel when replacing the clutch so it lasts longer??
This is true, you should always machine the flywheel AND pressure plate when you fit a new disc, or the mating sufaces may not line up, and wear out much quicker than they should.
--- Cut Here ---
Monsterbishi
Postby neo » Fri Mar 12, 2004 10:09 am
I know of a sub60 driver with a 94 fxgt, hes done 350,000 on the factory clutch =)
however he did stuff the baffles in his petrol tank and the radiator just blew apart =)
neo
Postby alastabesta » Mon Apr 26, 2004 2:34 am
hello everyone i'm back a month later with clutches that's about to go in 2 months i think... changed them august last year, done about 10000 k so far... now i'm getting REALLYYYYYY BLOOOODDDDYYYYY PISSSSSEEED OFFFF at my clutch!! this is rediculus!! changing a new set of clutch once a year?? what da hell... anyways, just wondering if any of you fellows could hook me up with a factory clutch and maybe tell me where to get my clutch installed cos nite parts did the job for me last time. GREAT PEOPLE AND GREAT SERVICE!! but they no longer exist... :roll: :cry:
(brendon: when can i bring my car to you to finish up the ex. temp gauge job? cos u told me to go back to u when i know wat rpm to set the overheat LED on but when i went back the whole garage was gone!!?? nyways, will txt/ring u soon thx a bunch)
2001 Caldina GT-T
alastabesta
Postby Ae92typeX » Mon Apr 26, 2004 11:06 am
Did you get the flywheel and pressure plate machined last time?,
thats some serious wear...it shouldent be doing that.
Either way, this time get the flywheel machined, and get a new clutch and pressureplate.
If ya still get the same wear again & its not your style of driving than maybe there is some misbalance or warpage in the shaft causing this?...although you would get some bad vibration if it was I would think.
Ae92typeX
Postby neo » Mon Apr 26, 2004 11:25 am
I know of a courier driver with an ae101 fxgt, 250,000k's on the standard clutch and its still ticking...
mines done 115 and is showing signs of wear...
Does everyone have a clutch pedal that only does anything at the very top, ie 2cm of movement will dissengage / engage the clutch?
neo
Postby alastabesta » Mon Apr 26, 2004 7:52 pm
mine engaged soon as i leave the pedal for about 5cm when new, now tyre squeals on hillstart cos it engages on the last cm or 2 >_<
total g.a.y.n.e.s.s.
2001 Caldina GT-T
alastabesta
Postby alastabesta » Mon Apr 26, 2004 7:56 pm
Ae92typeX wrote:Did you get the flywheel and pressure plate machined last time?,
nope didn't do that, mechanics told me that it's better if i do it as well but it won't matter THAT much as long as u change the clutch before its completely worn out and i was short of cash back then so... (innocent whistle)
2001 Caldina GT-T
alastabesta
