where to get driveshaft lengthened
Postby Ae92typeX » Tue Jun 01, 2004 3:47 pm
Anyone know where abouts on the shore (pref) I can go to get my driveshaft lenghtened?
Im in the process of manual'n my supra but since I cant find a manual shaft will get mine lenghtened as the auto ones are shorter.
Cheers.
Ae92typeX
Postby MrOizo » Tue Jun 01, 2004 4:17 pm
Not on the shore but Beattys in Manacow are the best that i have dealt with so far...
you going to be going single piece or 2 piece?
MrOizo
Toyspeed Legend
Postby Malcolm » Tue Jun 01, 2004 4:36 pm
I have a driveshaft sitting in the back of my GA61 that may be of use, you can have it for $40 if it will fit
Postby Ae92typeX » Tue Jun 01, 2004 7:28 pm
All_Fours wrote:I have a driveshaft sitting in the back of my GA61 that may be of use, you can have it for $40 if it will fit
Any chance you could measure its length?- Im pretty sure the fittings will be ok. If its the correct length then I'll def buy it.
otherwise cheers MrOizo, if thats not the right size I will look at takeing mine to those guys. Mine's a 2 piece.
Ae92typeX
Postby gtRFungi » Tue Jun 01, 2004 7:53 pm
thats not true. the left piece was attatched to the rocket cylynder
gtRFungi
Postby suckymotor » Tue Jun 01, 2004 8:09 pm
automotive drive line in sunnybrae rd glenfield
suckymotor
TS Original Member
Postby Malcolm » Thu Jun 03, 2004 8:46 pm
Just looking at the shaft, it looks a lot different to the one that's on the car, but I will go measure it....
it's just the front section, and from the tip of the shaft that goes into the gearbox to the 4 bolt flange at the back, it's 61cm
It is possibly the original one from the car, before it was converted to a 5MGE.
Postby Ae92typeX » Thu Jun 03, 2004 8:53 pm
Cool, cheers for that. Its definatly a different size to what I have. I will work out if its correct tomorrow- shaft next to my room, but boxes outside!
sounds hopefull, so please dont sell! :D
Ae92typeX
Postby Ae92typeX » Fri Jun 04, 2004 1:56 pm
is that 61cm pretty spot on?. Mine from the same points is 57cm and from what I work out it needs to be 64.5
argh, so close! :?
Ae92typeX
Postby Ae92typeX » Fri Jun 04, 2004 1:58 pm
in saying that, the input shaft does go in about 6cm from the seal.
anyone got an opinion on howmuch leeway could be used?
Ae92typeX
Postby Malcolm » Sat Jun 05, 2004 3:45 pm
Just come and take it. If it works then lucky you, if it doesn't then sell it for scrap to make back your petrol money.
PM me for my phone number
Postby Ae92typeX » Sat Jun 05, 2004 4:12 pm
pm'd :D
Ae92typeX
Postby Bazda » Sat Jun 05, 2004 9:20 pm
I know Precision engineering shorten drive shafts, so maybe they can lengthen them as well
located in albany
Users browsing this forum: No registered users and 32 guests
