The place for all technical car discussions. If you haven't already, read our
Disclaimer first!
AE101Z
Posts: 131 Joined: Tue Mar 25, 2003 11:36 am
Post
by AE101Z » Mon Jun 21, 2004 1:15 am
does anyone know 1 bar= ? psi
and 1 hp = ? kw
thanks
Posts: 3879 Joined: Fri May 02, 2003 4:12 pm
Post
by fivebob » Mon Jun 21, 2004 1:32 am
1 bar = 14.5psi
1hp = 0.746kw
GT4 20
Posts: 1086 Joined: Thu Jun 10, 2004 4:03 pm
Contact:
Post
by GT4 20 » Mon Jun 21, 2004 8:00 am
1 BAR = 14.7psi
Silvertop
Posts: 1256 Joined: Thu May 16, 2002 10:38 am
Post
by Silvertop » Mon Jun 21, 2004 9:07 am
Nope, fivebob is right.
1 BAR = 14.50377 psi
Al
Posts: 6146 Joined: Mon Jan 20, 2003 10:52 pm
Contact:
Post
by Al » Mon Jun 21, 2004 9:58 am
14.7psi is 1 atmosphere
also if you wanna get technical, 1 kg/cm2 = 14.2 psi
TrouserFxGt
Posts: 500 Joined: Sat May 25, 2002 2:27 pm
Post
by TrouserFxGt » Mon Jun 21, 2004 11:16 am
SS II wrote: 1 BAR = 14.7psi
a common misconception.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
EVLGTZ
Posts: 2347 Joined: Fri May 17, 2002 9:05 pm
Contact:
Post
by EVLGTZ » Mon Jun 21, 2004 11:34 am
Al wrote: 14.7psi is 1 atmosphere
yes but 1 bar does not equal 1 kg/cm
also a common misconception
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
Al
Contact:
Post
by Al » Mon Jun 21, 2004 11:50 am
Yep
GT4 20
Contact:
Post
by GT4 20 » Mon Jun 21, 2004 12:12 pm
I consider myself corrected
Gary
Posts: 11592 Joined: Sun May 02, 2004 3:01 pm
Post
by Adamal » Mon Jun 21, 2004 12:54 pm
This is part of why I prefer N/A
Al
Contact:
Post
by Al » Mon Jun 21, 2004 12:57 pm
Adamal wrote: This is part of why I prefer N/A
I thought it was because you like going slow?
Post
by fivebob » Mon Jun 21, 2004 1:04 pm
In which case do you know the conversion between in.hg and kPa
http://www.simetric.co.uk/si_k.htm contains all the metric conversions you should need.
Silvertop
Post
by Silvertop » Mon Jun 21, 2004 1:06 pm
EVLGTZ wrote: yes but 1 bar does not equal 1 kg/cm
Yeah something like 1 BAR = 1.019 kg/cm²
1 BAR = 0.98 atmosphere
cm of mercury anyone?
MrOizo
Toyspeed Legend
Posts: 6658 Joined: Thu May 16, 2002 8:26 pm
Contact:
Post
by MrOizo » Mon Jun 21, 2004 1:15 pm
Silvertop wrote: cm of mercury anyone?
Atmosphere = 76 cm Hg
(760 mm Hg
