boost and hp
boost and hp
Postby AE101Z » Mon Jun 21, 2004 2:15 am
does anyone know 1 bar= ? psi
and 1 hp = ? kw
thanks
AE101Z
Postby fivebob » Mon Jun 21, 2004 2:32 am
1 bar = 14.5psi
1hp = 0.746kw
Postby GT4 20 » Mon Jun 21, 2004 9:00 am
1 BAR = 14.7psi
GT4 20
Postby Silvertop » Mon Jun 21, 2004 10:07 am
Nope, fivebob is right.
1 BAR = 14.50377 psi
Silvertop
Postby Al » Mon Jun 21, 2004 10:58 am
14.7psi is 1 atmosphere ;)
also if you wanna get technical, 1 kg/cm2 = 14.2 psi
Al
Postby TrouserFxGt » Mon Jun 21, 2004 12:16 pm
SS II wrote:1 BAR = 14.7psi
a common misconception.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby EVLGTZ » Mon Jun 21, 2004 12:34 pm
Al wrote:14.7psi is 1 atmosphere ;)
yes but 1 bar does not equal 1 kg/cm
also a common misconception :)
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby Al » Mon Jun 21, 2004 12:50 pm
Yep :)
Al
Postby GT4 20 » Mon Jun 21, 2004 1:12 pm
I consider myself corrected :oops:
:wink: Gary
GT4 20
Postby Adamal » Mon Jun 21, 2004 1:54 pm
This is part of why I prefer N/A :)
Postby Al » Mon Jun 21, 2004 1:57 pm
Adamal wrote:This is part of why I prefer N/A :)
I thought it was because you like going slow? :P
Al
Postby fivebob » Mon Jun 21, 2004 2:04 pm
In which case do you know the conversion between in.hg and kPa :P
http://www.simetric.co.uk/si_k.htm contains all the metric conversions you should need.
Postby Silvertop » Mon Jun 21, 2004 2:06 pm
EVLGTZ wrote:yes but 1 bar does not equal 1 kg/cm
Yeah something like 1 BAR = 1.019 kg/cm²
1 BAR = 0.98 atmosphere
cm of mercury anyone? ;)
Silvertop
Postby MrOizo » Mon Jun 21, 2004 2:15 pm
Atmosphere = 76 cm Hg ;) (760 mm Hg
MrOizo
Toyspeed Legend
Postby Jools » Mon Jun 21, 2004 6:10 pm
Just download this people http://www.esbconsult.com/esbcalc/esbunitconv.html
Saves hurting your brain 8)
90 Celica GTR Turbo
184kw @ 14psi at the front wheels (Now running 17psi watch this space for dyno :) )
"Owner of the fastest Celica GTR in NZ (Until proved otherwise ;) )"
www.Jools.tk
Jools
Users browsing this forum: Bing [Bot] and 70 guests
