4age iratic idle
4age iratic idle
Postby skoty » Tue Aug 03, 2004 8:43 pm
Sorry if its already been posted before, but what causes a 4age such as mine to idle iratically, ie 1100-1600rpm?
skoty
Postby GTUWET » Tue Aug 03, 2004 8:47 pm
how do u mean like dus it rev up thn drop coz mine did that but higher in revs coz there was no water in radiator
[GTUWET] AnD lEaViN u DRiPpIn!!
GTUWET
Postby skoty » Tue Aug 03, 2004 8:50 pm
I mean it idles iratically such as continuously going up and down from 1100-1500rpm, seems a lil weird.
skoty
Postby GTUWET » Tue Aug 03, 2004 8:52 pm
hmm i duno mine used 2 idle at 1500 thn go str8 2 2500
GTUWET
Postby Lloyd » Tue Aug 03, 2004 9:02 pm
Starlet did that when it started to overhead once. And also did it because of a vacuum leak (inlet manifold gasket). Check all ya hoses and whatnot
Postby marke » Tue Aug 03, 2004 9:09 pm
mine idles high at the moment too. put your head out the window and sounds a bit like a rotor. have a look at the temp gauge, i thought mine was just broken but i now im under the impression the thermostat is broken so the ecu sends a rich petrol/air mix because it thinks the car is cold, so the car runs rich, uses more gas and i think can cause the idle to naff up a bit. but if your temp gauge reads normal then i would say you may be able to rule that idea out.
good luck
mark
No this is me in a nutshell..
"help im in a nutshell, how did i get into this bloody great nutshell... what kind of nut has a shell...like this.."
marke
Postby AceSniper » Wed Aug 04, 2004 3:30 pm
marke wrote:mine idles high at the moment too. put your head out the window and sounds a bit like a rotor. have a look at the temp gauge, i thought mine was just broken but i now im under the impression the thermostat is broken so the ecu sends a rich petrol/air mix because it thinks the car is cold, so the car runs rich, uses more gas and i think can cause the idle to naff up a bit. but if your temp gauge reads normal then i would say you may be able to rule that idea out.
good luck
mark
yea if ya temp reads low most of the time change the thermostat done mine afew weeks ago and the old thermostat was dated 1993 :lol: since the ecu thought it was always cold idle would be around 1500-2000rpm all the time
AceSniper
Postby FLAWLES » Wed Aug 04, 2004 6:00 pm
well i think u guys just solved my prob
time to buy a thermostat
nice one 8)
FLAWLES
Postby levin_it_large » Wed Aug 04, 2004 8:21 pm
i have a similar problem starts up @ 2K but after 5 or so minutes its goes back to normal idle, happens anytime of the day i could be back in the car in 20 minutes and it still revs @ 2K what could be my problem?
coolant and water needed in radiator? it a AE111 levin by the way
levin_it_large
Postby AceSniper » Wed Aug 04, 2004 8:53 pm
levin_it_large wrote:i have a similar problem starts up @ 2K but after 5 or so minutes its goes back to normal idle, happens anytime of the day i could be back in the car in 20 minutes and it still revs @ 2K what could be my problem?
Id start by replacing the termostat its cheap and easy todo ya dont need to fully drain ya coolent, what mine did was in open road an stuff itd run cold then in slow traffic itd heat up... since the termostat cant have been sealing fully itd always be cold.... so cold vvt wouldnt work
AceSniper
Postby skoty » Wed Aug 04, 2004 9:58 pm
It doesnt do it initally, after idling for like 2 minutes. Oh yeh my thermostat broke, so I removed it and didnt bother replacing it :oops: ... thought it was ok not to have a thermostat as they are mainly for cold as countries where its impossible to start an engine up with frezzing water running through it! So the thermostat is most likely the prob?
skoty
Postby starlet » Wed Aug 04, 2004 9:59 pm
hey
itll be ur idle speed control valve.
Either will be blocked with rust or be an airlock in it.
is located under throttlebody. pull it off and blow it out with compressed air then refit, fill car with coolant and bleed cooloing system
starlet
Postby marke » Wed Aug 04, 2004 10:19 pm
as i said above, my thermostat is broken. How hard is it to get to on a 20V silvertop? worth getting the mechanic to do, i understand the part is only about 20-30 $$ and a bit of labour so maybe a $100 all up doesnt seem that much but if its easy to do maybe id do it? anyone know or have done it before? cheers.
Mark
marke
Postby AceSniper » Thu Aug 05, 2004 12:05 pm
marke wrote:as i said above, my thermostat is broken. How hard is it to get to on a 20V silvertop? worth getting the mechanic to do, i understand the part is only about 20-30 $$ and a bit of labour so maybe a $100 all up doesnt seem that much but if its easy to do maybe id do it? anyone know or have done it before? cheers.
Mark
easy... If ya coolent is ok just open the drain plug an take some out into a bucket so the water is just below the head level, the thermostat is under the distributor.. unclip the plug for the temp and undo the two bolts an pop the housing off... pull the thermostat out put the new one in... make sure you line the little air bleed up with the top bolt, put everything back put ya coolent back in an keep toping it up as the air bleeds out.
AceSniper
Postby marke » Thu Aug 05, 2004 6:51 pm
ok
cheers for that 8)
mark
marke
Postby Lloyd » Thu Aug 05, 2004 6:58 pm
Be careful that the thermostat housing doesn't leak afterwards, could get expensive if you cook something.
