Turbo For A 3Y? (Yeah, I can hear you saying 'WTF is a 3Y!?)
Postby Muzzie » Sun Aug 22, 2004 1:10 pm
87 Hiace, got a 2.0litre 3Y motor, bored out slightly. I've seen other Hiaces with 'Turbo' plastered across the back, always assumed they was diesel, but saw one the other day that didn't sound like a diesel, smell or look (exhaust smoke) like one, and there was no RUC card on the windscreen, so I assume it must be a petrol one.
Anybody know if thats true, and if so, can I just bolt on the turbo to give my Hiace some more go?
Thanks
Mobile Car Servicing & Audio Installation - Inquire!
I'm Not Dumb, Im Just Selectively Observant!!!!
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1036
Had flash sig, but too big for TS :(
Muzzie
Regular Poster
Postby MetalupYoAss » Sun Aug 22, 2004 1:14 pm
nah the Y series engines are designed for commercial use, i doubt they would have ever made a turbo model, plus its not really worth turboing your 3Y, itll take so much work and not give that much more power
MetalupYoAss
Postby Muzzie » Sun Aug 22, 2004 1:18 pm
Bugger, thought that might be the case.
Got any suggestions what I should dump into it? I want some grunt!
HEHEHEHE. It's tooooo slow at the moment.
Muzzie
Regular Poster
Postby kingcorolla » Sun Aug 22, 2004 2:19 pm
cams, slight head work, side-drafts if fit-able (its a van!) extracters if available (its a 3Y!)
Ive worked on a 4Y (2.4l) and those engines respond well to basic mods
1983 Carina AA63 4age
kingcorolla
Postby flygt4 » Sun Aug 22, 2004 4:41 pm
hahahaha omg 3y's r so crap.....couple of my mates have had hiluxs with them in.ive helped one rip it out of his old lux.really not worth doing anything to.they juss sound filthy... that said tho a mildly worked 4y in an offroad hilux i seen went very well in the mud :D
flygt4
Postby NZ_AE86 » Sun Aug 22, 2004 7:32 pm
V8 Lexus, reliable, cheap and powerfull. 8)
NZ_AE86
Postby matt dunn » Sun Aug 22, 2004 11:02 pm
NZ_AE86 wrote:V8 Lexus, reliable, cheap and powerfull. 8)
or a 2.5l 1JZGE or GTE are quite cheap to.
Postby Muzzie » Sun Aug 22, 2004 11:32 pm
Question I now have to ask is....
2.5l 1JZGE or GTE, Or Lexus V8 - will it fit?, and easily?. I'll have to get a new geabox too, and I want a manual.
At least with something with some grunt I'll be able to pull my racecar around easily. Poor van struggles a bit at the moment.
And it doesn't sound too bad - they have a common fault where they leak around the downpipe (which mine does) and around 3000rpm it sounds beautiful in my humble opinion.
Muzzie
Regular Poster
Postby matt dunn » Sun Aug 22, 2004 11:40 pm
Muzzie wrote:Question I now have to ask is....
1JZ will be easier then the V8 because of the width,
but they both will require lots of custom work.
Postby Muzzie » Sun Aug 22, 2004 11:46 pm
Whats a 1JZ out of? Fuel injected I assume? I just like the space and practicality and originality of an older model Hiace, but its really too gutless for its own good.
I realize it will need a hell of alot of modification work, but is it doable for a reasonable price? I'm a student at present, looking for work (if anyone has anything!? I don't care what!) so it'll be a while before I do anything, but I wanna start saving now.
I'm gonna make that van go quick and look good .......... Or Bloody Well Die Trying!
Muzzie
Regular Poster
Postby Rollux » Mon Aug 23, 2004 1:25 pm
A mate of mine put a supercharger on his 3Y. It went quite a bit harder too!(For a 3Y!) He used a s/c of a 4agze, running about 6psi I think, headers, and 40mm carb (suck through setup). had to get inlet mani modded, custom crank pulley and some custom brackets. Didn't touch internals. Oh, plus converted dizzy to electronic and some timing setup to compensate for boost. Cost about $1200 all up, he doing most of the work. Worth it? Decide for yourself.
2002 Allex RS180 6 Speed
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Rollux
Postby Muzzie » Mon Aug 23, 2004 6:46 pm
Now that's what I'm talking about! Cheap power :) I wouldn't be doing much work myself because I haven't got the equipment, but surely it wouldn't cost too much more than that to have the work done. Now I just gotta save up so I can do that lol
But first, some mags and tints, then the exhaust and then the above probably :) Then i'll no doubt blow the gearbox, so I'll put in a Manual and be more than pleased :)
Woooohoooooooo. A plan emerges!
Muzzie
Regular Poster
Postby jjd » Mon Aug 23, 2004 10:06 pm
MetalupYoAss wrote:nah the Y series engines are designed for commercial use, i doubt they would have ever made a turbo model, plus its not really worth turboing your 3Y, itll take so much work and not give that much more power
In fact there is a turbo 3y,EFI as well,comes in a 88-89 townace super custom,with the sliding curtins of course.I know had to build a new front pipe for the thing as it was stuffed.
jjd
Postby Muzzie » Mon Aug 23, 2004 10:10 pm
Wooooooooooooooohoooooooooooo!!!!!!!!!!!!
EFi as well? Hmmmmm, might needa investigate that. Mines an 87 Super Custom Limited, has the elctrical curtains and stuff too.
Wonder what it's worth to change the intake for the EFi and bolt on a turbo? Gotta decide whether to Supercharge or Turbocharge :) But first things first - a job!
Muzzie
Regular Poster
Postby jjd » Mon Aug 23, 2004 10:14 pm
If you want I can try to get hold of the customer and get the chassis and engine codes for you.
jjd
Postby Muzzie » Mon Aug 23, 2004 10:15 pm
Yes please, that'd be a great help!
Thanks JJD
ANother thought, I'd have to change the head as well to allow for different compression ratio, and where is the Fuel pump on the EFi model? Mine is carbed and currently on the block. I assume the pump for EFi would be in the tank?
Muzzie
Regular Poster
Users browsing this forum: No registered users and 34 guests
