Screamer Pipe on a t25.
Postby 1598cc » Thu Sep 02, 2004 4:07 pm
Im wanting to put a screamer pipe on my civic.. its running a t25 turbo, but looking at it, it doesnt look like i can do it as both holes go into the housing and theres nothing i can make a flange up with to serparate it.
Kinda hard to explain, but on some turbos they have 2 holes, but in bewteen these holes is the flange which seperates each hole so its easy to make up a flange and bolt it on. On the t25 the flange would have it go inside to seperate both holes if you know what i mean?
Any advice?
ta
1598cc
Postby 92GTApex » Thu Sep 02, 2004 4:18 pm
By two holes i guess your meaning the Exhaust wheel where it is in the housing and the internal waste gate?
You will probably have to get a new dump pipe made (the best option) which should sort it all for you
Logan
Current ride: 92 Levin GT Apex
Current project: 91 Levin GT Apex (Crashed - It wasnt me)
www.area-51.co.nz
www.toyperformance.org.nz
www.lextreme.com
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1731
92GTApex
Postby Dr-X » Thu Sep 02, 2004 5:21 pm
Dr-X
Postby TrouserFxGt » Fri Sep 03, 2004 2:48 pm
see the rice specialists above
oh, and why??
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby Adamal » Fri Sep 03, 2004 2:54 pm
I think he got banned from NZHonda's for "Driving away from a meet too fast" :roll:
Postby 1598cc » Fri Sep 03, 2004 4:24 pm
92GTApex wrote:By two holes i guess your meaning the Exhaust wheel where it is in the housing and the internal waste gate?
Logan
Yeh thats what i mean..of course i need a new one, but am just wondering if its possible. Of course there is 2 holes, but on the t25 if i was to just make one, whereby the exhaust goes out and the internal goes to the atmosphere, the gases would get mixed up and would be pointless as there is nothing that is separating the holes as they sit about 1 inch into the housing and the downpipe touches around the edge... My description aint the best..
Dr-X wrote:
www.nzhondas.com?
oh, and why??
Why not.. I reckon they sound fine.. Theres just as many riced out toyotas on this forum as nzhondas.
1598cc
Postby Bazda » Fri Sep 03, 2004 5:50 pm
u can either get a piece welded into the exhaust housing to seperate the exhaust and wastegate but could ruin the housingby welding to it.
usually making a screamer pipe is done with a t3 turbo not a t25
Postby MetalupYoAss » Fri Sep 03, 2004 6:11 pm
what would nzhondas.com know about turbos? :roll:
MetalupYoAss
Postby the fallen303 » Fri Sep 03, 2004 6:50 pm
seen as you gotta get a custom dump pipe made, when they make the bit that bolts to the housing of the turbo, they can make a plate that welds to the dump pipe, not the housing, and it sits inside the housing and separates the exhaust wheel from the wastegate. personally i think screamer pipes are shite, but hey, whatever floats your boat.
true house of JZ
Stay true to the origin
the fallen303
Postby Bazda » Fri Sep 03, 2004 7:04 pm
just buy an external
Postby wde_bdy » Fri Sep 03, 2004 10:22 pm
Now here is a crazy idea.
You could try keeping your car legal. A screamer pipe isn't.
Callum
wde_bdy
Postby Boost_4_Life » Fri Sep 03, 2004 10:46 pm
for chrisakes why? They sound... ^insert word here^
keep it sleeperish dude, much better!
'83 KP starlet rally car, 20v powa!
The rally beast
The rally beast again!
Boost_4_Life
Postby suberimakuri » Fri Sep 03, 2004 11:23 pm
screamer on t25 is mean..... i had one on m10..
trick, don't go bigger then 35mm pipe... else the note will be too deep.
suberimakuri
Postby tianporn » Sat Sep 04, 2004 4:01 am
MetalupYoAss wrote:what would nzhondas.com know about turbos? :roll:
Umm theres a Forced Induction forum on NZHondasImage
tianporn
Postby MetalupYoAss » Sat Sep 04, 2004 1:03 pm
dosent mean they know anything about turbos, i dunno.. maybe they do
MetalupYoAss
Postby 1598cc » Sat Sep 04, 2004 1:22 pm
Boost_4_Life wrote:for chrisakes why? They sound... ^insert word here^
If youve seen my car, its pritty sleeper as it is...i had a screamer pipe on my old cyborg which sounded quite alrite
Yeh thats exactly what i was meaning, and was wondering if it would ruin it.
I was thinking that as well, but i doubt it cold seal it properly and would probly leak
1598cc
