92GTApex wrote:By two holes i guess your meaning the Exhaust wheel where it is in the housing and the internal waste gate?
You will probably have to get a new dump pipe made (the best option) which should sort it all for you
Logan
Umm theres a Forced Induction forum on NZHondasMetalupYoAss wrote:what would nzhondas.com know about turbos?
Boost_4_Life wrote:for chrisakes why? They sound... ^insert word here^
keep it sleeperish dude, much better!
u can either get a piece welded into the exhaust housing to seperate the exhaust and wastegate but could ruin the housingby welding to it.
usually making a screamer pipe is done with a t3 turbo not a t25
seen as you gotta get a custom dump pipe made, when they make the bit that bolts to the housing of the turbo, they can make a plate that welds to the dump pipe, not the housing, and it sits inside the housing and separates the exhaust wheel from the wastegate. personally i think screamer pipes are shite, but hey, whatever floats your boat.
Users browsing this forum: Bing [Bot] and 32 guests
