spoungy brakes
spoungy brakes
Postby B_giB » Thu Sep 23, 2004 11:52 pm
in my AE101 my brakes are spoungy, i brought it like that, thought it would just need bleeding...
did that, but nothing...
any suggestions???
Current: SXE10 Altezza
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby BADTOY » Fri Sep 24, 2004 12:20 am
maybe some new pads?
Go Hard Or Go Home
BADTOY
Postby kingcorolla » Fri Sep 24, 2004 12:41 am
did u bleed the brakes in the correct order?
1983 Carina AA63 4age
kingcorolla
Postby Ae92typeX » Fri Sep 24, 2004 11:29 am
yea, it sounds like the bleeding has not been done correctly and there is an air pocket in there somewhere. Does it feel the same with the car on and off?, possibly something to do with the vaccume valve faulty at a pinch?!
Ae92typeX
Postby blitza » Fri Sep 24, 2004 12:23 pm
make sure you bleed the brakes in the order, furtherest from the master cylinder up till the closest.
and then, there is the possibility of the sliding bolts that hold the caliper on being siezed, pull them to bits, clean and re assemble with hi temp anti sieze compound, (copper grease)
MAD Industries Limited
'97 GTT auto, -under rebuild, again.
the faster you go, the quicker you get there...
blitza
Postby CozmoNz » Fri Sep 24, 2004 4:09 pm
make sure you know the seutp of your master cylinder, if its diag, (FR and RL) make sure you do RR, FL, RL, FR, so it pushes it all out nicely :).
if its simple front and bak *i doubt*, do RL, RR, FL, FR
Rayne For President!
CozmoNz
Postby rollaholic » Fri Sep 24, 2004 6:41 pm
its diagonal split
Postby Spannergal » Sat Sep 25, 2004 12:11 pm
depending on the age of the car - due to the recent recalls - you could send it to toyota for a check that it ain't faulty.
Spannergal
Postby FLAWLES » Sat Sep 25, 2004 12:24 pm
check that your pads are installed proberly
my 101 gtz had spongy peddal and when i change the gay standard pads to race spec ones i found out that the back pads were never put in rite so i fixed this and wamm sorted
u will find its the most simpilst things that go wrong but u will all ways over look it
FLAWLES
Postby B_giB » Sun Sep 26, 2004 9:47 am
i defenatly bled th system properly mite try new pads and rotors see what that does
B_giB
Postby Lloyd » Sun Sep 26, 2004 11:38 am
If you hold your foot hard on the brake pedal does it slowly sink to the floor?
Postby mr30% » Sun Sep 26, 2004 1:26 pm
try this if split front/rear do 1 side front and back at the same time then the other side if split dia do back then front its faster and lets you get full peddle travel hope this helps
2 x 81 starlets/parts 2 x84 starlets ee82 ae82 1 x85 aw11 nz new 1 x84 aw11/parts 1 xae101
mr30%
Postby B_giB » Sun Sep 26, 2004 11:05 pm
no, pedal dosent sink slowley to floor... its just spoungy
B_giB
Postby matt dunn » Sun Sep 26, 2004 11:56 pm
B_giB wrote:no, pedal dosent sink slowley to floor... its just spoungy
Possibly that the brake fluid has absorbed moisture.
If you note on the lid it say's "use dot # from a sealed container"
Thats because if brake fluid is left open to the atmosphere it absorbs water into it and does not work properly.
By a new container of fluid and bleed it thru untill all the old fluid is out.
You can usually tell cause the fluid will change clolour as it comes out.
Start with the wheel that is furtherest from the master cylinder.
Worth a try. all it will cost is a bottle of fluid.
Matt
Postby B_giB » Wed Sep 29, 2004 1:36 am
sweet, mite try that... how about removing all fluid first??? and starting from scratch??? or is it not recommened to remove all fluid from lines?
B_giB
Postby matt dunn » Wed Sep 29, 2004 2:02 am
B_giB wrote:sweet, mite try that... how about removing all fluid first??? and starting from scratch??? or is it not recommened to remove all fluid from lines?
Definatly not !!
You drain the level down in the resovoir but dont drain it all or you will have real drama's getting all the air out again.
Postby kingcorolla » Wed Sep 29, 2004 3:09 am
Definatly not !!
at Toyota i got tought the easy way..
but at polytech, they teach you to pump ALL the old fluid out..So u learn how to BLEED the brakes of AIR, not just replace fluid..
kingcorolla
