20v RWD dizzy relocation
Postby spencer » Fri Oct 08, 2004 2:03 pm
Ok after seeing this on japanese sites for like over $1000 I thought id make myself one for like $20 Im just posting this to see if there is any interest in making up a few more of these. Still got to sort a few things like who can make up some longer leads with the silly plugs the 20v leads have heres a few pics
Brass bush is cut off and $5 bearing used dizzy is also shortened
Stainless bracket bolts to unused bolts where the FWD engine mount was
ms63 crown
spencer
Postby NA Drifter » Fri Oct 08, 2004 2:36 pm
how much you reckon it going to cost?.. if not too over priced, sure there is alot of interest. I might keen for one too.
Keith
NA Drifter
Postby spencer » Fri Oct 08, 2004 2:42 pm
maybe around $250, you would have to send me your dizzy so I could whack a bearing in it
ms63 crown
spencer
Postby KinLoud » Fri Oct 08, 2004 4:49 pm
Looks really good!
Is there a problem with the dizzy rotating the other way? Or does the computer not care?
Obviously the lead wires would have to be rearranged so they fire in the right order.
Ken
Hamilton
021 408 863
Postby vvega » Fri Oct 08, 2004 5:06 pm
dont forget about the home signal too :D
id say there a little bit of internal work to the dizzy
i have one here in peaces so later i cold look at whats required
pm me if your interested i was looking at doing this for a mate as well
vvega
Postby spencer » Sun Oct 10, 2004 12:29 pm
Yea vvega if your in hams feel free to come borrow mine to copy. I dont think there is any internal modifications needed, I have talked to a guy who has done it before and his works sweet I will look into it yet, cant see if it works sweet till I get some leads made anyone know where I can get leads made?
ms63 crown
spencer
Postby NA Drifter » Sun Oct 10, 2004 4:42 pm
what sort of bearing you using? I have heard that the best type of bearing to use is the A/C type of bearing.
Keith
NA Drifter
Postby suberimakuri » Sun Oct 10, 2004 10:47 pm
ahh.. saeco alternator bearings... go mint in your skateboard, just don't do any stairs with them, as they will shatter. :)
suberimakuri
Postby spencer » Mon Oct 11, 2004 10:43 am
NA Drifter wrote:what sort of bearing you using? I have heard that the best type of bearing to use is the A/C type of bearing.
just a general bearing from a book that fitted, it is only spinning at half crank speed which is max of about 4000rpm. most general ball bearings are good for well over that
ms63 crown
spencer
Postby Nuty|Mike » Mon Oct 11, 2004 11:10 am
id possibly be keen for one sounds a better idea then heaps of pingas on aftermarket ecu
05 Mazda Verisa .....for the Family
Nuty|Mike
Postby spencer » Mon Oct 11, 2004 11:16 am
sweet Ill let you guys know how it works in a couple of weeks when im on uni holidays
ms63 crown
spencer
Postby Mr Revhead » Mon Oct 11, 2004 11:22 am
hmm looks good, just rememeber to reverse the firing order of the leads and you should be sweet 8)
i think you may sell a few of those....
Postby blk_sti » Sat Jul 23, 2005 12:02 am
would you able to send me a pm about ur cell phone,
cos my friend intersted on the relocation kit, but he does not on internet often.
blk_sti
im keen
Postby frost » Sat Aug 13, 2005 2:48 am
hi names jackie, yeah i need one of these kits too. my email is j.cmoney@paradise.net.nz or cell phone 0211678657. i dont want to bash my fire wall(rangi mods) please give me buzz thanks
Postby spencer » Mon Aug 15, 2005 3:44 pm
Ok I have had heaps of pms about this I only made several and am at uni so dont have any time to get these made. But Im going to design the major bits of the bracket in solid works or something and get a few made. then just get a mate to shorten a few dizzys, if I ever get around to it Ill post up on here. Im now running megasquirt with edis which is a better way to go
spencer
hello guys very cool stuff on the distributor relocationq
Postby kit » Fri Oct 28, 2005 5:41 am
now! Qs; since honda distributor is almost identical to 20v setup can i used hondata dissy and honda ecu with hondata program to run my 20v?
has anyone done this before?or any one knows some one? or may be i'll be the first one to do this........ I'm thinking of using 92-95 ecu and dissy i'll post some pic later on
kit
Re: hello guys very cool stuff on the distributor relocation
Postby AceSniper » Fri Oct 28, 2005 11:19 am
kit wrote:now! Qs; since honda distributor is almost identical to 20v setup can i used hondata dissy and honda ecu with hondata program to run my 20v?
:roll: :roll: :roll: :roll: :roll:
No, no, No, no, No, no
AceSniper
Postby suberimakuri » Mon Oct 31, 2005 9:54 am
kit, don't see why not.
Just as long as you can tune hondata to work with the quads...
suberimakuri
k tuning and fab on the dizzy is almost done
Postby kit » Thu Nov 03, 2005 5:46 pm
ae86 20v turbo 16g setup home made manifold and honda ecu and wiring harness i'll be done in 3 weeks then i'll post some pic
kit
Re: k tuning and fab on the dizzy is almost done
Postby soopachargen » Wed Feb 22, 2006 4:01 pm
kit wrote:ae86 20v turbo 16g setup home made manifold and honda ecu and wiring harness i'll be done in 3 weeks then i'll post some pic
...looks at calendar.... looks questioningly at kit....
When in doubt, down and out.
soopachargen
