Brass bush is cut off and $5 bearing used dizzy is also shortened
Stainless bracket bolts to unused bolts where the FWD engine mount was
NA Drifter wrote:what sort of bearing you using? I have heard that the best type of bearing to use is the A/C type of bearing.
kit wrote:now! Qs; since honda distributor is almost identical to 20v setup can i used hondata dissy and honda ecu with hondata program to run my 20v?
has anyone done this before?or any one knows some one? or may be i'll be the first one to do this........ I'm thinking of using 92-95 ecu and dissy i'll post some pic later on
kit wrote:ae86 20v turbo 16g setup home made manifold and honda ecu and wiring harness i'll be done in 3 weeks then i'll post some pic
