terrytuffguy wrote:Also what about the no load ignition curve, right from idle right up to the rev cut?
terrytuffguy wrote:MATT DUNN...........You got an idea of what your ignition map looks like? Any help would be apprechiated.
terrytuffguy wrote:I'm running a Microtech which is alot different to use than a LINK. But all the settings would be the same. My aim is 200rwkw, then again peak power ain't no good if the rest of my torque curve is sheeet. Cheers for ya help anyway
Darren
Karl_Skewes wrote:if you're running av and 7.9:1 then for sure you're going to be able to run more timing.
i was running 10.3:1 and 15 lbs, and didn't want to tempt deto.
with 9:1 or so, 25 degrees should be ok.
too much advance is one of the quickest ways to blow up a motor.
