Ignition timing curve for a 4agte.
Postby terrytuffguy » Tue Oct 12, 2004 5:30 pm
What is a good timing curve for a turboed 4agze setup? I know there are alot of variables with setting your timming. But I need a basic curve so I can have something to work with......cheers
My 4AG powered starlet puts out 227rwkw & 12.39 @ 115mph........ YEA RIGHT, Tui.
terrytuffguy
Postby suberimakuri » Tue Oct 12, 2004 9:25 pm
20 degrees under boost.
you can start with 20degs static timing....and go up to 35 under low load, and you shouldn't need to go any lower.... 10 degrees for starting would be nicer too.
suberimakuri
Postby terrytuffguy » Wed Oct 13, 2004 12:14 am
Yea I had mine going from 35degrees under no load at 6000rpm to 25-30degrees under 10psi which caused it to detonate.
Is it true how you have to get your fuel mixtures right first otherwise you would be chasing your own tail? It's quite hard as I think I may be running to rich which I think is killing my power....
terrytuffguy
Postby Bazda » Wed Oct 13, 2004 10:07 am
my timing is at 20degrees on boost @15psi.
this seems to be a safe value and is what most of the 4agte boys run at.
my mixtures are also richer than normal but meh longer lasting engine.
Postby EVLGTZ » Wed Oct 13, 2004 3:16 pm
mine maps through to 16deg at top boost level of 22-23psi
Also running alil extra fuel for safety :wink:
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby terrytuffguy » Wed Oct 13, 2004 4:47 pm
It's damn hard to get your fuel mixtures right on the street, I have a fuel mixture guage but it doesn't work that well.
terrytuffguy
Postby terrytuffguy » Wed Oct 13, 2004 4:49 pm
Also what about the no load ignition curve, right from idle right up to the rev cut?
terrytuffguy
Postby EVLGTZ » Wed Oct 13, 2004 5:33 pm
terrytuffguy wrote:Also what about the no load ignition curve, right from idle right up to the rev cut?
mines 18 thru to 36 on low load.
what ecu are you using ?
EVLGTZ
EVLGTZ
Postby terrytuffguy » Wed Oct 13, 2004 6:31 pm
Microtech............Are you idling on 18 degrees? Just curious to know how fast the car advances verus the RPM. I know you have to retard the timming around max torque and then advance it again at the higher rpm.
terrytuffguy
Postby terrytuffguy » Wed Oct 13, 2004 7:29 pm
Microtech's are way different to use than a link and power FC thats for sure. Still trying to figure out how to use to properly
terrytuffguy
Postby terrytuffguy » Thu Oct 14, 2004 7:01 pm
MATT DUNN...........You got an idea of what your ignition map looks like? Any help would be apprechiated.
terrytuffguy
Postby matt dunn » Thu Oct 14, 2004 9:05 pm
terrytuffguy wrote:MATT DUNN...........You got an idea of what your ignition map looks like? Any help would be apprechiated.
My car has a LEM V3 and you have a V4 whigh has more rows in it,
so the program in my car will not be compatable with yours.
Also my car runs 100% avgas all the time and has water injection to help control detonation.
And 7.9:1 compression ratio helps too.
All I will say is it runs a fair but more than 20 degrees at 20psi.
Matt
Matt
Postby terrytuffguy » Thu Oct 14, 2004 10:38 pm
I'm running a Microtech which is alot different to use than a LINK. But all the settings would be the same. My aim is 200rwkw, then again peak power ain't no good if the rest of my torque curve is sheeet. Cheers for ya help anyway
Darren
terrytuffguy
Postby matt dunn » Thu Oct 14, 2004 10:54 pm
terrytuffguy wrote:I'm running a Microtech which is alot different to use than a LINK. But all the settings would be the same. My aim is 200rwkw, then again peak power ain't no good if the rest of my torque curve is sheeet. Cheers for ya help anyway
Darren
Found another 20v turbo link map on my computer that i copied out of someone else's car that i did a bit on.
Give me your email address and i'll mail it to you along with some other stuff you might find interesting.
Matt
Postby suberimakuri » Fri Oct 15, 2004 8:46 am
if you're running av and 7.9:1 then for sure you're going to be able to run more timing.
i was running 10.3:1 and 15 lbs, and didn't want to tempt deto.
with 9:1 or so, 25 degrees should be ok.
too much advance is one of the quickest ways to blow up a motor.
suberimakuri
Postby matt dunn » Fri Oct 15, 2004 6:15 pm
Karl_Skewes wrote:if you're running av and 7.9:1 then for sure you're going to be able to run more timing.
Exactly,
so the program in my car would be of no use.
The other program I have was a road car that ran on 96 so it has a much safer program. It has about 20 deg.
Interestingly too much ign advance can actually cause rund bearings in the bottom of the motor.
Matt
Postby vvega » Fri Oct 15, 2004 6:26 pm
that will be from the increased cylander presure from the inaudable detantion
but were talkin right on the edge of full blown nasty motor $&#$% det
v
vvega
Postby terrytuffguy » Sat Oct 16, 2004 11:49 am
boostindazz@hotmail.com. I will be running full avgas as it will be a club car at a later stage. But 96 will do for now till I get it dyno tuned.....
terrytuffguy
Postby matt dunn » Mon Oct 18, 2004 9:18 pm
Tried to email it to you but it won't send? Is the address correct?
Postby terrytuffguy » Mon Oct 25, 2004 1:35 pm
How large is the email your trying to send?........Sorry I have been away for the past week.
terrytuffguy
