AE92 fxgt headlight warning thingie - please help!!!
Postby gordon77 » Sat Jan 01, 2005 3:47 pm
hey ive got a 91 fxgt. it has or had a little speaker of some sort in the dash that emited a warning tone when you opened the door and the headlights were still on :lol: . this was working fine (good thing to have) but a few days ago it just stoped :? . i have the car manual but the wiring diagrams dont have anything about a warning system for the headlights that i can test or find.
is this dead forever or can i fix it? if so how to?
thanks ppl
What is RR?
gordon77
Re: AE92 fxgt headlight warning thingie - please help!!!
Postby CozmoNz » Sat Jan 01, 2005 4:28 pm
gordon77 wrote:hey ive got a 91 fxgt. it has or had a little speaker of some sort in the dash that emited a warning tone when you opened the door and the headlights were still on :lol: . this was working fine (good thing to have) but a few days ago it just stoped :? . i have the car manual but the wiring diagrams dont have anything about a warning system for the headlights that i can test or find.
thanks ppl
welcome to my world, cept my car never came with one!!!!
Rayne For President!
CozmoNz
Postby Zak » Sat Jan 01, 2005 5:52 pm
That warning has saved my ass so many times...
I would try and find the speaker that makes the tone, then trace it back to where ever it goes.
Zak
Postby B1NZ » Sat Jan 01, 2005 6:44 pm
Im with cosmoz - i never had one, if i did it wouldve saved my ass lots :oops:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby CozmoNz » Sat Jan 01, 2005 7:19 pm
B1NZ wrote:Im with cosmoz - i never had one, if i did it wouldve saved my ass lots :oops:
same for me... ive always gone, FUX)R and ran out, crank it and you can almost hear the starter motor screaming *ONE FUXING LAST TIME DAMNIT*.
as she revs into life :)
never have an alarm armed when ur drainging ur battery... try unlock the door
still enough power to use the alarm, BUT NOT TO TURN IT OFF.
CozmoNz
Postby Bling » Sat Jan 01, 2005 10:44 pm
thanks ppl
sorry, but how is that helping the guy with his query?
Postby B1NZ » Sat Jan 01, 2005 11:36 pm
We are giving him examples of what will happen if he doesnt get it fixxored! :P
Subaru GF8 Wagon
B1NZ
Postby nobody » Sun Jan 02, 2005 2:03 am
In my AE82, behind the stereo was a small box hanging down with a couple of cables running to it - it had something like 'buzzer' written on it. I think this was the headlight warning thingy - I can't be sure (this was 6 years ago), but I remember unplugging it thinking it was the >108km/h warning buzzer only to find it was for either the headlights or door open.
So, although this info's for the AE82, and my memory's not so good - it could be a good place to start to just pull out the stereo and see if there's a small box behind it and check if one of the cables has worked its way out :)
nobody
Postby Zak » Sun Jan 02, 2005 2:16 am
It's not there, as I've had the stereo out in my old ae92 FX-GT many times. I would say that it's part of the actual dash some where, so it'll be a pain to get at and fix.
The easiest way is to become friends with an auto electrician :wink:
Zak
Postby gordon77 » Sun Jan 02, 2005 10:32 am
well i have had the dash totally apart replacing the top that had cracked, i wasnt looking specifically for a buzzer of some sort but i didnt see one.
here is one twist to the story tho, last night i turned the car on and put my lights on but there was no dash lights for any of the guages, they still worked but just no illumination. there was also nothing for the centre console (heater, a/c stuff like that) either. :? oh yeah - all the warning lights come on when you stall it (purposely) and the indicator things work too and and also the highbeam light. :?
i did pull the stereo out the other day and redo the wiring with proper connectors (the previous owner had taped the bare wires up :roll: )
maybee i some how cut something without knowing and it was a power thing to the dash
What is RR?
gordon77
Postby CozmoNz » Sun Jan 02, 2005 11:03 am
gordon77 wrote:well i have had the dash totally apart replacing the top that had cracked, i wasnt looking specifically for a buzzer of some sort but i didnt see one.
just setup what i was going to do >.> run your headlight switch, through a relay, hooked up the through the ignition.
so your headlight switch (on / high etc), will only work when the ignition is set to "on" :). so, leave lights on, turn off car, lights turn off :D
CozmoNz
Postby Zak » Sun Jan 02, 2005 1:36 pm
Have you checked the dash fuses yet?
Zak
Postby gordon77 » Mon Jan 03, 2005 9:22 am
yeah i just thought of that, will do some time today and get a reply back...
What is RR?
gordon77
Postby kingcorolla » Mon Jan 03, 2005 8:18 pm
ok ok found blown fuse. i replaced it with same spec fuse (15amp) and it blew straight away when i turned the lights on with the door open. the buzzer thing buzzed for a nanosecond and then stoped (blew the fuse)
maybe a grounding problem??
haha, you took the whole dash out, to find out it was a fuse??
how does it feel? :lol:
na what I'D do is chuck a 20 amp in its place, if that dont work, I'D just get over it. wouldnt waste my time.
but if you really want it fixed, just wire up another one, to a light or sum? Just splice into the headlight feed, and use the same switch as the interior light.
piece of cake
or as cozmo said, just run the headlight feed through a relay, controlled by the ign switch, so theirs no need for the warning buzzer.
or you could rip the dash out again and have another look.. :lol:
1983 Carina AA63 4age
kingcorolla
Postby gordon77 » Tue Jan 04, 2005 10:29 am
um no... if you are able to read properly above i took the dash out to replace the top - nothing to do with the problem i have now.
i thought about replacing the fuse with a 20amp but didnt know what kind of implications that would have... the fuse is for my instrument lights as well so i cant see shit at night time. gotta hold the old phone up to the dash to check what speed your doing :?
What is RR?
gordon77
Postby gordon77 » Tue Jan 04, 2005 5:08 pm
heh replaced the fuse with 20amp, blew that straight away. replaced it with 30amp. blew that pretty much straight away :evil: :evil: :evil: :evil:
i have some U shaped spade connectors that will most likley fit into the slot nicley but i dont wanna go and screw any components in the circuit. is this a good idea or not.
reason for asking is coz i really need the circuit to work as my tail lights work off it. beeing a black car i will become pretty hard to see at night time...
What is RR?
gordon77
Postby kingcorolla » Tue Jan 04, 2005 6:12 pm
DONT DO THAT!!
the curcuit will just have a short to ground somwhere. Just inspect the wires and connections. A multimeter with audio continuity check will be very handy when finding the short.
kingcorolla
Postby gordon77 » Wed Jan 05, 2005 9:30 am
yeah ok but where do i start?? the circuit i will be testing has tail lamps, parking lamps, side lamps, number plate lamps, and instrument lamps on it. will there be a main connector that has all of the above on it???
What is RR?
gordon77
