is this dead forever or can i fix it? if so how to?
thanks ppl
gordon77 wrote:hey ive got a 91 fxgt. it has or had a little speaker of some sort in the dash that emited a warning tone when you opened the door and the headlights were still on. this was working fine (good thing to have) but a few days ago it just stoped
. i have the car manual but the wiring diagrams dont have anything about a warning system for the headlights that i can test or find.
thanks ppl
B1NZ wrote:Im with cosmoz - i never had one, if i did it wouldve saved my ass lots
CozmoNz wrote:gordon77 wrote:hey ive got a 91 fxgt. it has or had a little speaker of some sort in the dash that emited a warning tone when you opened the door and the headlights were still on. this was working fine (good thing to have) but a few days ago it just stoped
thanks ppl
welcome to my world, cept my car never came with one!!!!
gordon77 wrote:well i have had the dash totally apart replacing the top that had cracked, i wasnt looking specifically for a buzzer of some sort but i didnt see one.
here is one twist to the story tho, last night i turned the car on and put my lights on but there was no dash lights for any of the guages, they still worked but just no illumination. there was also nothing for the centre console (heater, a/c stuff like that) either.oh yeah - all the warning lights come on when you stall it (purposely) and the indicator things work too and and also the highbeam light.
i did pull the stereo out the other day and redo the wiring with proper connectors (the previous owner had taped the bare wires up)
maybee i some how cut something without knowing and it was a power thing to the dash
ok ok found blown fuse. i replaced it with same spec fuse (15amp) and it blew straight away when i turned the lights on with the door open. the buzzer thing buzzed for a nanosecond and then stoped (blew the fuse)
maybe a grounding problem??
kingcorolla wrote:ok ok found blown fuse. i replaced it with same spec fuse (15amp) and it blew straight away when i turned the lights on with the door open. the buzzer thing buzzed for a nanosecond and then stoped (blew the fuse)
haha, you took the whole dash out, to find out it was a fuse??
how does it feel?
or you could rip the dash out again and have another look..
