LPG vs Pump
LPG vs Pump
Postby _will_ » Sun Feb 27, 2005 9:16 pm
Does anyone know what the performance differences between LPG and normal pump petrol?
I've heard that LPG has a higher octane rating, but not sure if it gives greater performance?
Also, what is the cost of setting up for LPG, and does it affect the engines longevity?
Cheers!
Celica GT-Four ST185
Starlet KP61
http://toyspeed.blakjak.net/profiles/profile.php?id=1304
I don't always not make no sense
_will_
Re: LPG vs Pump
Postby Monsterbishi » Sun Feb 27, 2005 9:26 pm
_will_ wrote:Does anyone know what the performance differences between LPG and normal pump petrol?
Cheers!
LPG is a popular fuel choice for performance v8's in the USA, google it and you should find heaps of results.
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby vvega » Sun Feb 27, 2005 10:01 pm
lpg is a great fuel
to bad the carbs cost more than a small jumbo jet
but other than that its a forced induction dream
and inviroment friendly too :D
v
vvega
Postby Leon » Sun Feb 27, 2005 10:02 pm
You can't use LPG in motor race events, for safety reasons, as (among other reasons) LPG heavier than air, and often doesn't disperse in the event of a leak.
There was one dude who was campaigning for LPG to be allowed into motorsport for several years. He now runs his car on pump gas, and I understand he has been quoted as saying that his car has never gone better since changing to petrol.
Draw your own conclusions ...
Postby vvega » Sun Feb 27, 2005 10:34 pm
funnely enough petrol is also heaver than gas :D
lol
c**t when you run out too
hard to get it in ya gas contanier :D
v
vvega
Postby _will_ » Sun Feb 27, 2005 10:47 pm
Bugger...the reason i was thinking of it was for racing!!
Glad you told me that before I dove head first into a pile of crap :lol:
Starlet KP61
_will_
Postby Leon » Mon Feb 28, 2005 11:04 am
You can use if for off roading (you know, those buggies and big 4wd things), if that was the style of racing you were looking at, but that's about it. But nothing that's permitted under MotorSport NZ.
Postby Malcolm » Wed Mar 02, 2005 3:29 pm
i believe the problem with LPG is that although it has a higher octane rating, it comes into the engine in a gaseous form, rather than liquid, like normal petrol does, so you get less mass of fuel and less power from burning it.
Postby Flyboy » Wed Mar 02, 2005 3:53 pm
An LPG unit can cost FROM $3500.....
Flyboy
Postby Inane » Thu Mar 03, 2005 12:04 pm
with a properly set up CNG or LPG system, you can have HUGE gains.
but you need to have it set up right,
not just a poor job of getting a Petrol system to run gas.
LPG and CNG have the similar cooling effects as Nitrous Oxide (not the same level of change in torque)
and due to its gaseous state and Higher octane (and the Pressure that you can inject it into the engine under)
It responds very very well to high boost environments.
Over in Australia they have a company called Gas Research, they make performance Gas conversion kits,
they have _THE_ fastest NA's around, (I'm talking for the average joe blow, not specialised applications either)
We are talking HQ Kingswood, with a Gas research manifolds, ported Black motor Head, running straight gas = 160.2 rwKw
Its all about how you use it.
and Also, you can Use LPG as a fuel for Drag racing over here, (just not anything else)
Inane
