I have a silvertop one with this number:
3f30 3334
And a blacktop one with this number:
6k130881
also do I still use a silvertop cambelt when runing blacktop pullys?
thanks
AceSniper wrote:hmm I know its been done...
my cam wheel is getting noisey so i have a set of blacktop cams with pullys to go in, I think the blacktop belt is one tooth longer? dono hmm :/ an I think silvertops advance 15deg aswell
10k 20v wrote:yep
RedMist wrote:Has anyone thought of counting teeth? If the belt is one tooth bigger or smaller then both the lnlet pullies and the crank pulley has to have a different number of teeth or the cams would rotate out of timing to the point pistons will collect valves.
I guess the real question is why do you want to use the blacktop pulleys?
ke70wagon20v wrote:the cambelts are the same well they look identical. I think both pulleys have the same advance just by moving them by hand and measureing how much they move. I was thinking the duration is the same on both 20v's just looks like more lift in the blacktop cam
Users browsing this forum: Google [Bot] and 28 guests
