VVT pullys
VVT pullys
Postby AceSniper » Thu Feb 24, 2005 6:58 pm
so what's different between blacktop and silvertop? if any..
I have a silvertop one with this number:
3f30 3334
And a blacktop one with this number:
6k130881
also do I still use a silvertop cambelt when runing blacktop pullys?
thanks :P
AceSniper
Postby RedMist » Fri Feb 25, 2005 7:05 am
Don't quote me but I suspect they reprofiled the VVT pulley in order to give a better response from the longer duration inlet cam in the blacktop, or possibly just to avoid the pistons hitting the valves.
Either way, its more than likely matched to the blacktop inlet cam.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby spencer » Fri Feb 25, 2005 2:22 pm
the cambelts are the same well they look identical. I think both pulleys have the same advance just by moving them by hand and measureing how much they move. I was thinking the duration is the same on both 20v's just looks like more lift in the blacktop cam
ms63 crown
spencer
Postby RedMist » Fri Feb 25, 2005 2:33 pm
Yep Blacktop has more lift, which would imply more duration, possibly not ramp to ramp but 10 ro 50 thou it would be easliy measurable. Especially as it is a reasonable lift increase from 7.97 to 8.20mm.
Would be interesting to note if Toyota did reprofile the Blacktop VVT pulley. Could you throw one on a degree wheel?
RedMist
Postby Mr Revhead » Fri Feb 25, 2005 3:18 pm
i thought silvertop was 10deg advance and blacktop 15.....
the cambelts are a different partnumber... so there must be some difference
weather it prevents swapping them i dont know
Postby AceSniper » Fri Feb 25, 2005 8:28 pm
hmm I know its been done...
my cam wheel is getting noisey so i have a set of blacktop cams with pullys to go in, I think the blacktop belt is one tooth longer? dono hmm :/ an I think silvertops advance 15deg aswell
AceSniper
Postby matt dunn » Fri Feb 25, 2005 11:15 pm
AceSniper wrote:hmm I know its been done...
From the spec sheet I have,
the pulleys both have the same advance in them,
and the cams have the same stated duration,
but the blacktops open 5 degree's earlier and close 5 degrees earlier than the silvertop,
and silvertop has 7.97mm lift opposed to blacktop's 8.2mm.
Exhaust cams are same spec.
If you believe what you read on the net.
Matt
Postby spencer » Mon Feb 28, 2005 8:39 am
RedMist wrote: Could you throw one on a degree wheel?
Im gunna take one to mates work in town this arvo and try it
ms63 crown
spencer
Postby 10k 20v » Mon Feb 28, 2005 8:36 pm
the cambelts are different, blacktop misses a tooth (could be wrong there, might have an extra one?????) and is wider mainly due to the hydralic belt tensioner arrangement and as far as i know the wheels are just indexed differently while the blacktop exhaust wheel has 3 spokes instead of 5
whats a full stop 8O
10k 20v
Postby AceSniper » Tue Mar 01, 2005 6:09 pm
so in all this talk? :lol:
I should use silvertop cambelt, and line the blacktop pullys upto the same place as the silvertop ones would?
thx
AceSniper
Postby 10k 20v » Tue Mar 01, 2005 6:35 pm
yep
10k 20v
Postby matt dunn » Tue Mar 01, 2005 7:16 pm
10k 20v wrote:yep
I'd say no.
I would still use the silvertop belt as said,
(presuming that you have a silvertop motor)
but since you are using the blacktop cams and pulley's i'd line them up as per blacktop, the way the cams are meant to be.
Just my view.
Matt
Postby RedMist » Tue Mar 01, 2005 8:12 pm
Has anyone thought of counting teeth? If the belt is one tooth bigger or smaller then both the lnlet pullies and the crank pulley has to have a different number of teeth or the cams would rotate out of timing to the point pistons will collect valves.
I guess the real question is why do you want to use the blacktop pulleys?
RedMist
Postby matt dunn » Tue Mar 01, 2005 11:40 pm
RedMist wrote:Has anyone thought of counting teeth? If the belt is one tooth bigger or smaller then both the lnlet pullies and the crank pulley has to have a different number of teeth or the cams would rotate out of timing to the point pistons will collect valves.
I dont think the number of teeth on the belt will matter, as long as it's the correct length for you application,
The silvertop belt is for std tensioner and blacktop if you are using the hyd tensioner,
but as you bought these off trademe ( i was watching that auction too) i kinda presume that you are fitting them to a silvertop.
but the main point that you bring up is,
is the number of teeth on the blacktop and silvertop pulley the same, and do they still have twice the teeth of the crank pulley as that's what determines the timing not rotating out of sync?
Matt
Postby AceSniper » Wed Mar 02, 2005 10:03 am
just counted the teeth on the blacktop wheels... 36 teeth on each, anyone gota silvertop one they can count? :D
yea I want to fit them to a Silvertop mainly coz the vvt pully onit is getting noisey, an iv hurd of blacktop cams in a silvertop so I thought id just fit the whole lot since a silvertop wheel would have prolly cost more than what i payed for the lot.
AceSniper
Postby Mr Revhead » Wed Mar 02, 2005 11:06 am
all versions of 4age cam pulleys have 36 teeth 8)
Postby Mr Revhead » Wed Mar 02, 2005 11:07 am
oh btw a new silvertop vvt pulley is about $190
Postby AceSniper » Wed Mar 02, 2005 1:02 pm
blacktop cams an pullys $110 8)
AceSniper
Postby spencer » Wed Mar 02, 2005 2:45 pm
just to clear it up both wheels advance 15 degrees checked it out
ms63 crown
spencer
Postby ROBODISCO_20v » Wed Mar 02, 2005 6:41 pm
ke70wagon20v wrote:the cambelts are the same well they look identical. I think both pulleys have the same advance just by moving them by hand and measureing how much they move. I was thinking the duration is the same on both 20v's just looks like more lift in the blacktop cam
Silver top cam belt has 111 teath
Black top cam belt has 110 "
ROBODISCO_20v
