R,T and A series motors?
Postby rwd_mayhem » Mon Mar 07, 2005 7:09 pm
i have been told that R,T and A series motors all have the same mounts. my mates got an ae70 which has a 2t-geu in it so A and T are true. now will an 18R-GEU fit in too? a few people have said no but a few people have said yes so what do u think?
current: 1975 Valiant Regel
rwd_mayhem
Postby wde_bdy » Mon Mar 07, 2005 7:35 pm
Absolute rubbish, none of them are the same.
wde_bdy
Postby thaphatty » Mon Mar 07, 2005 8:33 pm
yep total shit. R series mounts are about 6" further forward than A series
thaphatty
Postby rwd_mayhem » Mon Mar 07, 2005 9:06 pm
then how does the 2t-geu fit straight onto the A series mounts in the ae70 ?
rwd_mayhem
Postby z|gen » Mon Mar 07, 2005 9:09 pm
maybe they changed the mounts or modified them slightly ?
AE91 SUPERCHARGED COROLLA
z|gen
Postby thaphatty » Mon Mar 07, 2005 9:20 pm
thats what happens when you try to put a 18RG onto RWD A series mounts
thaphatty
Postby wde_bdy » Mon Mar 07, 2005 9:21 pm
te71 rolla wrote:then how does the 2t-geu fit straight onto the A series mounts in the ae70 ?
Pull the T series out of your TE71 and drop in a 4A. Guarantee it won't bolt straight up. They will have swapped around bits and pieces or the motor won't be sitting the same as the factory T series motors. Some cars are close but are not identical.
Callum
wde_bdy
Postby rwd_mayhem » Mon Mar 07, 2005 9:31 pm
in the ae70 it doesnt look like the mounts have been changed/altered.
rwd_mayhem
Postby offensive » Mon Mar 07, 2005 9:35 pm
might of done what i did, changed the subframe to an ae70 or ae85 - 6 one
above this is a line
quote: "Reclusive girls dont shave their pubes"
offensive
Postby Logan » Mon Mar 07, 2005 9:36 pm
i think that more to the point is that x-members and mounts can be mixed and matched to swap about anything into anything...
SR Sold. Onto Other Things
Logan
Postby wde_bdy » Mon Mar 07, 2005 9:40 pm
thaphatty wrote:thats what happens when you try to put a 18RG onto RWD A series mounts
Very strange, the 18RGEU in my KE70 has the mounts much closer to where the T and A series ones sit.
Callum
wde_bdy
Postby rxtoy » Mon Mar 07, 2005 9:47 pm
i've got an R and a T series crossmember for my celica and there is a drastic difference in where they situate the mounts, like it looks like a reversed crossmember pretty much.
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby RS13 » Mon Mar 07, 2005 9:49 pm
I know a guy with a 2TGEU AE70, he had to use a TE71 crossmember/subframe to get things to fit. If you have a TE71, an AE70 engine crossmember may bolt up..
RS13
Postby wde_bdy » Mon Mar 07, 2005 9:52 pm
RS13 wrote:I know a guy with a 2TGEU AE70, he had to use a TE71 crossmember/subframe to get things to fit. If you have a TE71, an AE70 engine crossmember may bolt up..
Except all the T series are box and the A series are rack so a bit of extra work sorting that.
Callum
wde_bdy
Users browsing this forum: No registered users and 57 guests
