BZGEE wrote:pyro_sniper2002 wrote:yes but they have 4a-fe's
Could you not get one and do a 20V conversion and just loos the front drive shafts?
Emperor wrote:Or just buy a RWD car?
1998 wrote:Another interesting point is I find this article contridicted by the fact that most (~80% Anyone know exactly?) of the preorders for MR2's were for woman.
10k 20v wrote:the other advantage of fwd is no trans/drive shaft tunnel and more interior space
TygerTung wrote:Manufacturers went to FWD, simply because customers liked them better.
EVEN if it did cost more to make a RWD, which I can't see how it would, you just drop the chassis down over the drivetrain and engine, suspension etc. EVEN if it was cheaper, it wouldn't be cheaper if noone brought it right?
With FWD you get more interior space, it's much quieter (much less gearbox and diff noise) the handling is much more predictable and you get beter fuel economy. FWD often tends to be lighter too, so the car handles more nimbly.
I think trying to convert FWD to RWD is a silly idea, as the manufacturer already spent millions designing a FWD chassis to handle well etc, if you just go $&#$% around with that, and don't spend millions of dollars designing it, you might end up with somthing crappy.
I'd recomend just starting with a RWD car.
And I don't think converting a 4WD to RWD is a good idea either, as you have the added weight of 4WD, but you don't have the advantages of 4WD.
Just what I think.
thaphatty wrote:saw a RWD AE101 signature class car at the 6hr enduro @ puke last night, came second over all, $&#$% that car was mean.
