Mark 2 Turbo without enough boost.
Postby AJz » Thu Jun 16, 2005 11:19 pm
dotdog wrote:Id like to see you flick a switch 6000 times a minute cosmo!
i would pay money to see that, lol
I had vtax :(
AJz
Re: Mark 2 Turbo without enough boost.
Postby pervert » Fri Jun 17, 2005 9:06 am
Santas> :lol: Good shit man, good to see it is catching on, did it go pretty hard until it cut?
Cozmo> ...
pervert wrote:
provided they don't come from Cozmo (no offence)...
Anyone apart from Cozmo got any tricks?
pervert
Postby RedMist » Fri Jun 17, 2005 9:32 am
Thats 12,000 times per minute. Once on, once off for every RPM.
However a cheap additional injector controller from JCar would work. And for the tuning by ... smell?? that they are going to do, you wouldnt even need an RPM reference.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby pervert » Fri Jun 17, 2005 9:45 am
CozmoNz wrote:shes not worth much pervert... things that cant get warrents, cant get warrents... and yes, thats my wet blanket because you got it from me for dirt cheap :).
Last I checked, rust was repairable? :?
No more thanks, on topic only.
pervert
Postby dohca » Fri Jun 17, 2005 10:00 am
sounds like a boost cut
does it have one of those stupid solinoid controlled enrichment ecus?
if so there should be a seperate solinoid for the boost cut
unplug it and there will be no boost cut
be careful not to unplug the obvious one, aka enrichment solinoid
or else things can get butchered rather easy
dohca
Postby Mr Revhead » Fri Jun 17, 2005 10:49 am
that "7th" injector is the cold start injector.
Postby EVL GSXR » Fri Jun 17, 2005 12:14 pm
Bahahahahah that's some serious switch flicking.. If you could pull that off you'd be the ticket for the ladies ha ha ha..
www.lowndvs.co.nz
1997 GSXR750 - 11.23 @ 128mph to date - Round 280kph Top Speed to date
http://toyspeed.blakjak.net/profiles/profile.php?id=793
EVL GSXR
Postby 1598cc » Fri Jun 17, 2005 2:23 pm
cold start injector wont dispurse evenly. extra injectors are a the way to go.
1598cc
Postby spencer » Fri Jun 17, 2005 3:10 pm
or maybe for himself?
ms63 crown
spencer
Postby Dell'Orto » Fri Jun 17, 2005 5:00 pm
How good is the exhaust on it? Wont be the cause of it cutting out, but wont help that freeboosting spool either. Cut all the mufflers out :D
Postby pervert » Fri Jun 17, 2005 5:01 pm
Mmm, Boost wrote:How good is the exhaust on it? Wont be the cause of it cutting out, but wont help that freeboosting spool either. Cut all the mufflers out :D
Its a decent size, then gets choked in the rear, might just cut the rear one off... :twisted:
pervert
Postby flygt4 » Fri Jun 17, 2005 5:26 pm
hahaha rangimods...gotta love em
flygt4
Postby CozmoNz » Fri Jun 17, 2005 7:25 pm
quit repeating what i say to you!
but ANYWAY, the cold start injector, who cares... its not designed to run on 15+psi anyway, so using a rungi injector wont make much difference...
and i told you, unplug that damn solinoid...
Rayne For President!
CozmoNz
Postby pervert » Fri Jun 17, 2005 7:33 pm
CozmoNz wrote:quit repeating what i say to you!
Do my eyes not see that for themselves?
CozmoNz wrote:and i told you, unplug that damn solinoid...
Doesn't work... :D
pervert
Postby matt dunn » Sat Jun 18, 2005 12:30 am
Does it have an AFM?
If so then the AFM will reach the end of it's calibration range and the ECU will say stop.
There is no way around it, normally.
BUT.... since you seem intent on destroying it anyway,
pull the top black plastic cover off the AFM, and somehow with something NOT MADE OF METAL limit the travel of the AFM so it will stop a bit short of the end of it's travel.
This will mean two things.
it will stop the boost cut.
it will lean it out at full boost and destroy the engine rather quickly.
My guess as this is not normal practise is it will last about 1 or 2 minutes on full boost with this mod before it will never run again.
To get around this connect a a wire to the earth sid eon the injectors and when it climbs off the boost gauge swith the injectors on and they will full flow the fuel into the engine. this may make it last longer, or it may flood it and foul the plugs.
NOTE: These mods are only if you wish to destroy your engine.
Matt
Postby pervert » Sat Jun 18, 2005 12:49 am
matt dunn wrote:BUT.... since you seem intent on destroying it anyway,
This is the best thing I have ever heard...it suits me so well... :lol:
Thank you so much, your post is just what I needed to know... :D
pervert
Postby Santa'sBoostinSleigh » Mon Jun 20, 2005 9:56 am
so the question on all of our minds:
did it last the weekend??!!?!?
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby pervert » Mon Jun 20, 2005 10:03 am
:lol: :lol: :lol: :lol:
No, it's dead, but not through over-boost, I blew up the AFM with some 'testing' and a soldering iron...
It will live another day...
pervert
Postby Santa'sBoostinSleigh » Mon Jun 20, 2005 10:05 am
you gotta love the testing that involves soldering irons, hammers and side cutters :twisted:
Santa's Mega Sale
Postby pervert » Mon Jun 20, 2005 10:16 am
Sometimes axes get thrown into the mix too, then things get really broken... :lol:
pervert
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
