beerad wrote:Hey guys just installed the lowering springs into the caldina, it only lowerd about 2inches, i really needed it to go down 4. This was with RSR lowering springs, what you reakon the best bet is to get it lower without doing something illegal
Dont forget, new springs settle after a while too, so they may go down another 10mm in a month or so.
Mr Revhead wrote:wtf! 2 inches is rather a bit, and 4 inches is huge.....
youll prob need shortend struts. i think 4 inches is a bit much on a caldina. but the choice is yours
compressing springs is... well... if you want to keep any semblance of ride....
All_Fours wrote:in response to the comments regarding going super low with coilovers = good handling - not true
The problem with going very low, no matter what kind of struts/shocks/springs you use, is the changes in suspension geometry. On MacPherson strut suspension, once the lower control arm goes past horizontal you will get positive camber on any further suspension travel, such as when you're cornering at speed. This is very undesirable! If you really want to go low and get good handling, you need to look at your suspension design, look into roll center adjusters, and have a look at the bump steer characteristics, as you will often find that when you go very low, the region of normal suspension travel experiences severe bump steer.
