Turbo Timers
Turbo Timers
Postby Toxic » Tue Jul 05, 2005 11:00 pm
Hey guys
What are your opinions of turbo timers. Do i need to invest in one.
Are they just a waste of gas, or do they actually protect the turbo.
I have heard that cooling the engine is better done while moving rather than standing still. Others say if you dont have one you will cook your seals.
please advise.
Wat are some good brands to purchase and what sort of $$ should i be putting into one.
Toxic
Postby CozmoNz » Tue Jul 05, 2005 11:24 pm
got a water cooled turbo?
fivebob wrote:
fivebob wrote:Either way Ceramic bearings wouldn't help if the turbo needed cooling down, (which it doesn't as it's water cooled), the oil would coke regardless of what bearings were used.
turbonetics wrote:Q: Do I need to run water-cooling lines to the turbocharger?
A: Water provides a certain margin of safety when the engine is shut off. Thanks to engine heat, coolant normally continues to circulate through the bearing housing, thus drawing heat away from the bearings. If the car is shut down properly and the engine is allowed to cool it is not mandatory to use water lines. Whether to use water lines depends on the convenience of plumbing the car and the vehicle's intended use.
Seems like complete agreement to me.
RS13 wrote:So, does this mean shutting an oil-cooled car down properly would be letting it run momentarily after extended high temps, utilising a turbo timer?
I'd hardly call them oil cooled, they're really air cooled with pressure fed oil lubrication, there's not enough oil flow too cool anything.
And if turbo timers are pointless, then why do so many big-name cars over Japan have them? Surely if say, HKS make them, they must do something?
Yes, for non water cooled turbos like TD-05,TD-06,T-67, T-78 T-88 etc. However as Toyota Turbos (well at least all the modern one I know about) are all water cooled, so like I said;
Turbo timers are just wank factor on water cooled turbos.
Search = friend :)
Rayne For President!
CozmoNz
Postby Alex B » Tue Jul 05, 2005 11:45 pm
For day to day driving no, if they were nessary they would be factory fitted as they are on trucks.
Postby michion » Wed Jul 06, 2005 12:17 am
does anyone know if a caldina gtt 97 is water cooled or have I wasted
$200 putting a T Timer on.
michion
Postby Lanius » Wed Jul 06, 2005 11:23 am
Its a newer turbo ("ct20b") so it will probably be water cooled. The only reason you need a t-timer is if you plan on boosting right up until you climb out the driver's door. If you slow down and cruise for the last 2 or 3 minutes of each journey, then the timer would be redundant / wasting fuel.
I laugh when people rock up to our place and their cars are left running for about 5 minutes to let the factory turbo running factory boost cool down :roll:
Lanius
Postby CozmoNz » Wed Jul 06, 2005 1:22 pm
michion wrote:does anyone know if a caldina gtt 97 is water cooled or have I wasted
if its a factory turbo, which it will be i imagine, its water cooled..
in which case, nup, dont need it :).
so, youll need a turbo timer if:
fivebob wrote:for non water cooled turbos like TD-05,TD-06,T-67, T-78 T-88 etc. However as Toyota Turbos (well at least all the modern one I know about) are all water cooled
CozmoNz
Postby michion » Wed Jul 06, 2005 1:33 pm
F#!k! Anyone want a turbo timer? Cheap!
michion
Postby sleeper_rolla » Wed Jul 06, 2005 1:56 pm
sorry to bluuz in but i am putting t3/4 on my ze motor-will i need to have a turbo timer?
I wish i was an expert :?
Under construction be sure to visit soon :D
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1571
sleeper_rolla
Postby CozmoNz » Wed Jul 06, 2005 2:13 pm
sleeper_rolla wrote:sorry to bluuz in but i am putting t3/4 on my ze motor-will i need to have a turbo timer?
we should make a form.
here i will...
*question*, Is your turbocharger water cooled?
[if yes, goto yes]
[if no, goto no]
yes = you dont require a turbo timer
no = you do not require a turbo timer
YAY..........
CozmoNz
Postby Lanius » Wed Jul 06, 2005 3:47 pm
CozmoNz wrote:[if yes, goto yes]
[if no, goto no]
YAY..........
:roll:
Lanius
Postby riddles » Wed Jul 06, 2005 4:27 pm
Ok, so how do you tell if you have a water cooled turbo? I have a '94 st205.
riddles
Postby Fraud » Wed Jul 06, 2005 5:06 pm
Does it have water lines to and from the turbo?
Fraud
Postby CozmoNz » Wed Jul 06, 2005 5:29 pm
have you modified the turbocharger?
chances are im guessing you havnt if you dont know about water lines etc.
so its going to be a ct20b... which is water cooled. Thus, you dont NEED a turbo timer. We have one in the mr2 mainly just for the boost gauge (peak etc). i never turn it off though when im about to get out... so i just let it do its 10 second thing, might turn it down to 5 actually....
CozmoNz
Postby mr pad » Wed Jul 06, 2005 5:46 pm
CozmoNz wrote:so i just let it do its 10 second thing, might turn it down to 5 actually....
WOW
mr pad
Postby CozmoNz » Wed Jul 06, 2005 5:48 pm
World of Warcraft?
CozmoNz
Postby mr pad » Wed Jul 06, 2005 6:03 pm
What the hell? No, I was just so impressed.
mr pad
Postby CozmoNz » Wed Jul 06, 2005 6:37 pm
I never aim to impress...
especially who ever you are... 8O
CozmoNz
