Jebus wrote:In some applications, such as carbys the extra oil flowing around the inlet through the carbs side of things isnt always a bad thing.
How so? just wondering.. both my cars have carbys.. one has blowby - would be interesting to know.
so it will be roughly the same for blacktop 20v rite? any picsMr Revhead wrote:pretty easy.....
on my silvertop.....
out of cam cover at the gear box end --------- catch can.
out of cam cover at the intake side -------- catch can
this one is is where it goes from the cover into the intake, make sure you block off the intake pipe very well, you dont want an air leak there!
iv kept the pcv valve in place as it acts as an adaptor.
make sure you have all connections tight and leak free!
so basiclly all iv done is made any line coming out of the cam cover vent straight into a catch can.
Mr Revhead wrote:i emptied my catch can again the other night, first time in 2 months. FULL (500ml) of water
randomly blew the rear main oil seal outa the back of the motor. Only happened because I had the breather outlet on the rocker cover blocked up and then rear main was the weakest link
