oil temp gauge
oil temp gauge
Postby LEV_101 » Mon Aug 15, 2005 9:17 pm
hi there.
can someone please give me some infomation on oil temp gauge. what do i need ? how hard is it to install ? and will in work on my levin ae101 ? im new to this stuff. thanks alot :) !!!
LEV_101
Postby Ae92typeX » Mon Aug 15, 2005 11:14 pm
What do you want one for?- on a normal road engine, imo, not really much point,
But anyway...they are not too hard to install. If you just want a basic one, I'd get an electric one from repco. can be used for oil or water temp. the sender and instructions come with them.
you will then need to find a thread, or tap a new one into the engine somewhere (that bit could be more difficult). If you cant find one in the block and dont want to tap a new one, at a pinch you could place it into the drain plug area, but i'd advise against it as that places it at the bottom, and too close to the ground- its likely the wire, or worse sensor could get ripped out fairly easily with nasty consequences. Would be easy to weld a thread into the lower side of the sump for it however- just means dropping the pan.
mount the gauge, wire it all up and youre away.
Ae92typeX
Postby DJ » Mon Aug 15, 2005 11:17 pm
I got a spare Greddy one sitting here.
DJ
Postby FLAWLES » Tue Aug 16, 2005 4:11 pm
or u can go the full nelson and get a oil cooler and plug it it to that " like me "
u realy dont want to be drilling oils in stuff
FLAWLES
Postby Ae92typeX » Tue Aug 16, 2005 6:46 pm
FLAWLES wrote:u realy dont want to be drilling oils in stuff
good point, I should have added, its not simply a case of drilling the block and away you go. Any drilling would require the area to be flushed out as you dont want any bits of metal lodging into beerings or anything!
Plumbing into a cooler would be a good idea. If not that then I'd do the weld a thread into the sump suggestion I had- then you can take it off the car to get it done and cleaned before putting it back ont he car.
Ae92typeX
Postby wde_bdy » Tue Aug 16, 2005 6:49 pm
Or you just tee off the factory pressure guage/switch. 8)
wde_bdy
Postby Ae92typeX » Tue Aug 16, 2005 6:58 pm
was going to suggest that, but you would need some pretty funky adapter pieces as many temp sensors have afew cm of the sensor sticking into the block past the thread.
still, if their easy enough to attain, that'd be the go.
Ae92typeX
Postby LEV_101 » Tue Aug 16, 2005 7:42 pm
is there any easy way out of this ? like not drilling holes ... just stick it somewhere... ??? thanks for the help guys! :D
LEV_101
Postby Ae92typeX » Tue Aug 16, 2005 9:40 pm
As purple_beasty says;
purple_beasty wrote:Or you just tee off the factory pressure guage/switch. 8)
I said wrote:was going to suggest that, but you would need some pretty funky adapter pieces as many temp sensors have afew cm of the sensor sticking into the block past the thread.
the I thought about it and it wouldnt be anything special, just an extended threaded adapter to accomodate the sensor probe.
Only thought is, would it get enough oil circulation to give a precise reading? I assume it probably may, but someone may have something better than an assumption to back it up?
I mean pressure gauges not need to be in the line of flow, but water temp sensors generally are, so maybe a 'T' wont measure adequatly?
Ae92typeX
Postby AceSniper » Tue Aug 16, 2005 10:25 pm
iv just got an adaptor plate that sits between the engine and oil filter with 3 threded holes init there around $40 if you can find one in a shop, they save alot of messing around as the factory ae101 20v ones sit under the aircon bracket.
AceSniper
