Whats Your Revs To Speed?
Postby Muzzie » Sun Oct 02, 2005 2:43 pm
Morbid curiousity got the better of me, and I'm curious to see what revs peoples car do at 100 in top.
Heres what my turbo uno does :)
Yet Another Oversized Image
1.3L, EFi, Turbo, 5spd, 185/60/14 tyres.
Can anyone top that :) And I have pics at 80 as well to show proportions if anyone is interested.
My Hiace does 2300 at 100.
Mobile Car Servicing & Audio Installation - Inquire!
I'm Not Dumb, Im Just Selectively Observant!!!!
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1036
Had flash sig, but too big for TS :(
Muzzie
Regular Poster
Postby DriftMonkey » Sun Oct 02, 2005 3:33 pm
My sentra does 1400 at 50kmh, 1990 at 70kmh (the needle is JUST below the 2000 marker) and 2800 at 100kmh, which seems quite high after seeing yours. Its a gutless heap of crap so I guess they lowered the gear ratios and final drive so it actually picked up speed when you put your foot down :lol:
DriftMonkey
Postby Mad Murphy » Sun Oct 02, 2005 3:55 pm
My rona sits at about 2600 at 100.
1989 Supercharged AW11, 1981 Sprinter GT, 1991 Primera s**tmobile.
Facelift AW11 Parts Wanted!
Mad Murphy
Postby SIKTOY » Sun Oct 02, 2005 4:24 pm
Mums VT commodore V8 does 1800ish at 100kph. :lol:
and the response is much better than fiat turbo 8)
Back when my SR was 4spd it did 3800 at 100kph :cry:
bye bye fuel. Much better with the K50 now.
ALL MEN DIE, NOT ALL MEN TRULY LIVE!
Current: 80 SR Project,
Check Out My Profile, Including CURRENT Pics!
Previous: 90 GT Sedan, 85 FXGT, 77 SR with 18RG, + many more.
Pink shaved pussy pic!!!
SIKTOY
Postby Chelles » Sun Oct 02, 2005 4:25 pm
Mirage sits at 4100rpm in 5th at 100km 8O
she's a little noisy at that
'96 RS Mirage Race car... (and when I'm a good girl; EVO 1!!) 2014 Toyota Hilux - daily driver!!
Gone but not forgotten: Race car AE85.6 Levin, AE101 Trueno, 84 MR2 AW11, 94 MR2 SW20, SR coupe KE35, AE92 FXGT, AE91 FXZS...
Chelles
TS Original Member
Postby Al » Sun Oct 02, 2005 4:32 pm
How long until it caught on fire Muzzie or something fell off?
'The parts falling from this car have been manufactured to the highest Italian standards'
Al
Postby Muzzie » Sun Oct 02, 2005 4:35 pm
Al wrote:How long until it caught on fire Muzzie or something fell off?
Actually, it's been pretty good. Since the motor conversion I haven't had a single problem with it. It just goes and goes.
And SIKTOY, the VT might have been 'response', but it is alot newer, and bigger motor, but won't use anywhere near the same amount of gas as the uno will :D And the uno will go just as fast :P
Muzzie
Regular Poster
Postby SIKTOY » Sun Oct 02, 2005 4:38 pm
Muzzie wrote:And SIKTOY, the VT might have been 'response', but it is alot newer, and bigger motor, but won't use anywhere near the same amount of gas as the uno will :D And the uno will go just as fast :P
I know, Im just pulling your leg, its a different class of car all together. :wink:
Thats one economical little screamer, like Al said though, hope it holds together sweet.
SIKTOY
Postby Muzzie » Sun Oct 02, 2005 4:41 pm
When it breaks something I'll let you know :)
Muzzie
Regular Poster
Postby Truenotch » Sun Oct 02, 2005 4:58 pm
My car does about 3200 at 100kph, the gear ratios are pretty low I suppose.
Truenotch
Postby V8MOFO » Sun Oct 02, 2005 4:59 pm
muzzie, you need petrol!
Anger is seldom without argument but seldom with a good one.
Image Fact of the day: I have only updated my fact of the day on time, Three times.
V8MOFO
Re: Whats Your Revs To Speed?
Postby fivebob » Sun Oct 02, 2005 5:20 pm
Muzzie wrote:Morbid curiousity got the better of me, and I'm curious to see what revs peoples car do at 100 in top.
So what have you changed from the standard Uno, which according to my calculations requires 2700rpm for 100km/h, or perchance is that tacho a typical piece of Italian electronics (I've always though they should be pronounced Vague-lia :D)
Hmmm, perhaps you and Akane should swap tachos as his seems to be reading a bit high :lol:
BTW I've created a page where you can check what you speed to RPM should be http://www.users.on.net/~fivebob/speedcalc.htm
Postby Muzzie » Sun Oct 02, 2005 5:43 pm
V8MOFO wrote:muzzie, you need petrol!
No I don't, it's still 1.8 of a tank from empty, and then once it reaches empty the light comes on and it does another 70 odd km :P
I don't know what my final drive or gear ratios are :( But how about I use the tacho I have sitting on the dash (aftermarket) and compare...... If they're the same then the original must be accurate......
Muzzie
Regular Poster
Postby deaf_rattle » Sun Oct 02, 2005 5:52 pm
2200rpm at 100kph in the supra
that leaves 5000rpm of fun after that
Postby fivebob » Sun Oct 02, 2005 6:06 pm
Muzzie wrote:I don't know what my final drive or gear ratios are :( But how about I use the tacho I have sitting on the dash (aftermarket) and compare...... If they're the same then the original must be accurate......
According to http://www.carfolio.com/specifications/ ... ?car=38269 the final drive ratio is 3.35 and top gear is 0.88
Given that the top speed of the car is 200km/h and they make 118hp @6000rpm I think it's pretty safe to assume it's not doing top speed @ 3000rpm 8O
Postby Al » Sun Oct 02, 2005 6:08 pm
Yes I once owned an Alfa 75, the 1750 model with twin side draught dellortos. Lovely sounding car but when I first got her the tacho read on the low side. I would have the thing screaming in each gear only to be shown 5000rpm on the tacho :lol:
Al
Postby Muzzie » Sun Oct 02, 2005 6:36 pm
Can I just point out that's the wrong car :)
Thats a Series 2, with 1400 turbo.
The earlier 1300 were quicker :) And I have the earlier :P
Muzzie
Regular Poster
Postby fivebob » Sun Oct 02, 2005 7:35 pm
Muzzie wrote:Can I just point out that's the wrong car :)
As long as I can point out that your car has less HP (105 @5750) and lower top speed (196km/h) :P
BTW if this car is the right one the Final drive is 3.59 and top gear is 0.863, thus making you tacho error even more Vague-lia :D
Postby Si » Sun Oct 02, 2005 8:54 pm
http://www.geocities.com/z_design_studio/
That is a good calculator for working out ratios and shizzel
Current: , '96 SubaruImpreza
Si
Postby aliluya » Mon Oct 03, 2005 12:18 am
Mine i think does 100kph in fifth at around 2800rpm
2008 Toyota Highland 4WD LTD is awesome!!!
2001 E39 530i BMW
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1727
aliluya
