flygt4 wrote:my current injectors are about standard size and were at 95% at 174kw atw. i believe 440's will stretch to just over 200kw atw.
a set of 550's out of a us market 2jzgte or latemodel 3sgte will leave you plenty of headroom and probly be capable of more than you'd ever need. . i had my set tested and they actually flowed 500cc@44psi.
flygt4 wrote:fro memory there was someone else who had a set of 3sgte 540's flowed at 500 odd cc@44psi. could be luck of the draw? or the export supra ones could be slightly different than gen4 3sgte ones. *shrug*
flygt4 wrote:matt dunn wrote:What colour are they?
The 440's I have are grey,
and the 550's are blue/green color.
Matt
umm ones that flowed at 500 are red
HRT wrote:My 365s flowed a touch over 400 on 45psi. Guess its luck of the draw aye Bazda
Bazda wrote:HRT wrote:My 365s flowed a touch over 400 on 45psi. Guess its luck of the draw aye Bazda
HUH??
matt dunn wrote:Bazda wrote:HRT wrote:My 365s flowed a touch over 400 on 45psi. Guess its luck of the draw aye Bazda
HUH??
lol,
youre not reading that as 45psi boost are ya?
That's 400cc min inj flow rate at 45 psi fuel pressure
Bazda wrote:FYADUP jsut had his re-dynoed and his also maxed out on 12psi with 173kws on the standard map ecu, when he had shitty manifolds he was running 15psi easy but with only 152kws.
so it seems the flow of your manifolds makes a difference.
