MR2 speedo cable = snapped?
Post Reply
Post by RomanV »
My speedo stopped working yesterday, (1990 NA SW20) I would imagine due to a snapped speedo cable.
Has anyone replaced this before?
Or alternatively, are there any other possible causes?
I would imagine it would be a PITA job to do, if it is the cable.
Post by Dell'Orto »
Check the pin that comes off the speedo driven gear inside the gearbox, mine rounded off so didnt drive anymore :?
Cost like $18 for Toyota for a replacement.
I also have a new driven gear here if thats your problem ;)
Post by RomanV »
Hehe, thanks, will do.
Will PM you if that is the case. 8)
minijrocks
Post by minijrocks »
i think my wire is fraying. it sometimes reads and sometimes doens't. Does anyone have an engine diagram or links to, of when there wire goes from, i dont know what to look for in the engine bay, behind the cluster looks all good.
Post by Dell'Orto »
In what kind of car? Cause thats exactly what mine did before it rounded off properly.
minijrocks
sorry, its a trueno 1991 4age :D Just need to know where the wire comes thru firewall and into gearbox, i cant seem to find the wire :?
Post by Alex B »
tis a cable on the back of the gearbox, prety hard to miss, its not a wire as such well not in the electrical sence.
Post Reply
