Bazda wrote:30kg!! hmm i havent had a car with 30kg rear seats before, what they made of? cast iron?
considering they fold down and have a steel backing on them i would have to agree there would be a huge saving!
TWSTD wrote:no im not... would be nice if the greddy manual was in gramatically correct english, let alone complete with technical information!
fivebob wrote:TWSTD wrote:no im not... would be nice if the greddy manual was in gramatically correct english, let alone complete with technical information!
I thought this page was reasonably self explanatory.
Set the first box to lauch RPM, second on to max RPM, and third one to power shift max RPM, plus add a switch for power shift detection (on the clutch?).
Then set the throttle position above which Ignition cut will occur, add an ignition timing adjustment (retard the ignition to build boost and for a mild anti-lag effect), and select the number of pulses before launch control deactivates.
