Noise when engaging reverse gear...
Postby Ae92typeX » Sat Nov 12, 2005 8:32 am
additional to vvega's post, have you adjusted the idle speed at all?- if you have stepped it up higher at all, this tends to make it louder.
Ae92typeX
Postby Smoken » Sat Nov 12, 2005 9:23 pm
normaly if it does it in reverse gear only it is usaly the clutch or cable
if u cant beet em bash em!!!!!!
Smoken
Postby vvega » Sat Nov 12, 2005 9:37 pm
he is right dude if you idle speed is to high it will crunch
remeber no syncromesh so the faster it turn the more unhappy it will be to enguage
v
vvega
Postby Crimson Tears » Sun Nov 13, 2005 1:41 am
First gear does have a syncroniser. Just pull the $&#$% out, strip it and learn something.
Crimson Tears
Postby vvega » Sun Nov 13, 2005 6:36 am
Crimson Tears wrote:First gear does have a syncroniser. Just pull the $&#$% out, strip it and learn something.
i have
many of them and lots of times
there is no sincro to go from netral to first
sorry mate were not all just forum mrchanics here :)
v
vvega
Postby Crimson Tears » Sun Nov 13, 2005 1:51 pm
So tell me vvega, what do you think the syncronizer unit is there to do?
It does two things:
It prevents gear clashing during shifting
It locks the output gear to the output shaft.
To select first gear, the sleeve of the first gear synchroniser is moved forwards by a selector fork which fits into the groove of the sleeve. This operates the synchroniser before the teeth on the sleeve engage the dog teeth on the first gear. With the dog clutch engaged, the first gear is locked to the mainshaft.
Straight out of my automotive text book.
And by the way, I'm a Toyota dealership technician.
Crimson Tears
Postby vvega » Sun Nov 13, 2005 10:12 pm
lol i know who you are and what you do i even know how long youve been doing it
perhaps you might even remeber chatting to me for hours on msn
IMO it acellerates the gear to match the output shaft speed and allows teh dogs to aling and mesh
i guess its how you look at it aye
ps i just bought that gt4 back again and reconing the motor as we speek
are you sure the first has the synco hub
i dont recall ever seeing one on the cluster :S
v
vvega
Postby mr pad » Mon Nov 14, 2005 9:57 am
vvega wrote:1st and reverse have no syncro's
Does 1st not having syncros apply to most cars or just this box?
I know of some cars have syncromesh in reverse (Some Audi's..) Just curious....
Also Perv my k50 makes a similar noise when going into reverse, not all the time, like yours. Its a real metal clunk... noise... Been doing it ever since I had the car though...
mr pad
Postby vvega » Mon Nov 14, 2005 2:46 pm
lots of cars do have a synco on reverse
normally when you hear a clunk your idle is to high or you moving when your sticking it in there
many boxes do not have 1st gear syncros reason been i guess .when do you stick it in first when your driving ??
or shift down to first while your moving
and been the fact this is a k40....early 80's late 70's box ........ its not really a modern luxery box ethier
v
vvega
Postby pervert » Mon Nov 14, 2005 2:50 pm
vvega wrote:its not really a modern luxery box ethier
v
Big meanie... :lol:
The noise has gone for now, so I don't care anymore... :lol:
pervert
Postby EVL GSXR » Tue Nov 15, 2005 6:57 am
pervert wrote:The noise has gone for now, so I don't care anymore... :lol:
Classic :lol: :lol:
Car look's bloody good now with the 17's in all 4 corner's fella :D :D
www.lowndvs.co.nz
1997 GSXR750 - 11.23 @ 128mph to date - Round 280kph Top Speed to date
http://toyspeed.blakjak.net/profiles/profile.php?id=793
EVL GSXR
Postby pervert » Tue Nov 15, 2005 7:28 am
Yeah, shame about the miss and the panelwork though... :lol:
pervert
Postby EVL GSXR » Tue Nov 15, 2005 8:57 am
pervert wrote:Yeah, shame about the miss and the panelwork though... :lol:
Look's quite straight wouldn't take much to sort the outside if you need a hand give us a yell could prob get it painted at a good price aswell fella..
Mate just painted his Silvia Saturn Black and look's friggen mean..
www.lowndvs.co.nz
EVL GSXR
Postby barryogen » Tue Nov 15, 2005 2:43 pm
Don't know what causes it, but in each toyota I've driven(85 corolla, 93 Hilux, 95 Curren, 87 Corona, 01 Corolla) have all made a noise when putting them into reverse... the only way I found around it, is to clutch-in, select 2nd gear, then select reverse, and got no noise since... it has become my standard "going into reverse" gear change.
barryogen
2ZZ Guru in training
Postby mycoolcar » Tue Nov 15, 2005 2:55 pm
barryogen wrote:Don't know what causes it, but in each toyota I've driven(85 corolla, 93 Hilux, 95 Curren, 87 Corona, 01 Corolla) have all made a noise when putting them into reverse... the only way I found around it, is to clutch-in, select 2nd gear, then select reverse, and got no noise since... it has become my standard "going into reverse" gear change.
Exactly the same for me. 89 hilux, 89 corona, 92 corolla. They will all make the clunk going into reverse if you dont go to 2nd and then to reverse.
mycoolcar
Postby ollieboy » Tue Nov 15, 2005 5:09 pm
Yeah same with me as well aye. I tried saying that earlier on a few posts back and just got shot down. I thought it was a Toyota thing and all of them did it because all our Toyotas have done it.
ollieboy
Postby CozmoNz » Tue Nov 15, 2005 5:19 pm
i said it right at the beginning, but good ol pervie, got his panties in a twist.
Rayne For President!
CozmoNz
Postby pervert » Tue Nov 15, 2005 8:18 pm
Does everyone on here have reading comprehension problems? :lol:
Yes, cars clunk when going in to reverse, but no, they don't clunk and grind at the same time... :roll:
It was a clutch issue, and Cozmo, I thought I told you no-one needs your advice...taking mechanical advice from you is like a asking a blind man for directions... :lol:
pervert
Postby ollieboy » Tue Nov 15, 2005 9:42 pm
pervert wrote:Does everyone on here have reading comprehension problems? :lol:
Yeah thats what all our cars do. A sort of grinding and whirring. Thats why I thought it as normal. I guess not but they do stop when you do that second gear first thing.
ollieboy
Postby barryogen » Wed Nov 16, 2005 9:21 am
pervert wrote:It was a clutch issue, and Cozmo, I thought I told you no-one needs your advice...taking mechanical advice from you is like a asking a blind man for directions... :lol:
FYI: Blind people are normally really good to ask for directions, they can usually give you pinpoint accuracy on where things are, and amazingly what to look out for.
ie: go through 3 intersections, turn right, go through two intersections, past the school on your left, turn right.
They seem to take more in... no idea why, maybe they need to.
barryogen
