vvega wrote:1st and reverse have no syncro's
mr pad wrote:vvega wrote:1st and reverse have no syncro's
Does 1st not having syncros apply to most cars or just this box?
I know of some cars have syncromesh in reverse (Some Audi's..) Just curious....
Also Perv my k50 makes a similar noise when going into reverse, not all the time, like yours. Its a real metal clunk... noise... Been doing it ever since I had the car though...
pervert wrote:The noise has gone for now, so I don't care anymore...
pervert wrote:Yeah, shame about the miss and the panelwork though...
barryogen wrote:Don't know what causes it, but in each toyota I've driven(85 corolla, 93 Hilux, 95 Curren, 87 Corona, 01 Corolla) have all made a noise when putting them into reverse... the only way I found around it, is to clutch-in, select 2nd gear, then select reverse, and got no noise since... it has become my standard "going into reverse" gear change.
pervert wrote:Does everyone on here have reading comprehension problems?![]()
Yes, cars clunk when going in to reverse, but no, they don't clunk and grind at the same time...![]()
It was a clutch issue, and Cozmo, I thought I told you no-one needs your advice...taking mechanical advice from you is like a asking a blind man for directions...
pervert wrote:It was a clutch issue, and Cozmo, I thought I told you no-one needs your advice...taking mechanical advice from you is like a asking a blind man for directions...
