Toyota Levin Ae111 Pinging Problems. Anyone Who Can Help???
Postby mauvis99 » Mon Nov 14, 2005 7:13 pm
Just a question, how do i get my Bzg to stop pinging? It like chokes sometimes when im hitting just over two thousand revs, when its cold or after a little rest, but if i rape it, it seems to sort itself out and it stops pinging. Anything i can do to fix it like send it in for some sort for repair? thanks. Im runnin 98, thought it would sort it out but yeah. any help appreciated thanks.
mauvis99
Postby gepsk8 » Mon Nov 14, 2005 8:26 pm
what gas u running? u done a tune up lately?
gepsk8
Postby Kitrix » Mon Nov 14, 2005 8:28 pm
mines the same. when u hit 2k revs when its cold it starts to shit out, but if ya give it a bit of gas it sorts itself out. fine when she warms up, running 98 and fresh out from a service
http://toyspeed.blakjak.net/profiles/profile.php?id=1846
Kitty. 7 cars in 3 years... got commitment problems?
Kitrix
Postby mauvis99 » Mon Nov 14, 2005 10:12 pm
Ok sweet so at least its not only my car, has anyone found a solution?
mauvis99
Postby matt dunn » Mon Nov 14, 2005 10:29 pm
mauvis99 wrote:Ok sweet so at least its not only my car, has anyone found a solution?
What ign timing is it set at.
Try 2 deg less than factory.
Postby AceSniper » Mon Nov 14, 2005 10:45 pm
As Matt says... Timming
AceSniper
Postby mauvis99 » Mon Nov 14, 2005 10:49 pm
How do i go about doing that?
mauvis99
Postby Alex B » Mon Nov 14, 2005 11:12 pm
Get a mechanic to do it for you, its one of those if you have to ask things :D
Postby mauvis99 » Tue Nov 15, 2005 5:31 pm
So to get the ignition turned 2 degrees i have to get a mechanic to do it? cant i do it?
mauvis99
Postby Ae92typeX » Tue Nov 15, 2005 5:37 pm
if you have timiing lights, know how to use them and know how to set it up on your car yes...otherwise, if the answer is no, its easier to just get a mechanic to do. Find one that charges in 1/2 hours and it wont cost much.
Ae92typeX
Postby Kitrix » Tue Nov 15, 2005 8:59 pm
my problem was it has no oil :oops:
Kitrix
Postby matt dunn » Tue Nov 15, 2005 11:25 pm
Kitrix wrote:and fresh out from a service
Kitrix wrote:my problem was it has no oil :oops:
Postby Kitrix » Wed Nov 16, 2005 5:11 pm
yeh... worrying aint it!
Kitrix
Postby Ae92typeX » Wed Nov 16, 2005 5:20 pm
sounds like someone got the traniee apprentice to get those servies out the way...
Years ago when working at a servo, I was amazed to see how often it happened. People just out of a service, I'd reccomend they still check their oil. On so many occasions situations like the oil had been filled, filter put on, but the engine had not been run to fill the filter up the rechecked...
Ae92typeX
Postby Kitrix » Wed Nov 16, 2005 5:38 pm
yea. it started making the noise that it was making when the big end went again. i just about died, but checked the oil and there wasnt a drop. my bad for not checking i spose. wont be doing that again
Kitrix
Postby mauvis99 » Thu Nov 17, 2005 6:07 pm
Anyone got any other solutions to help with pinging?
mauvis99
Postby Punter » Thu Nov 17, 2005 10:51 pm
mauvis99 wrote:So to get the ignition turned 2 degrees i have to get a mechanic to do it? cant i do it?
have you checked that yet? would be the most likely cause
I love deadlines. I like the whooshing sound they make as they fly by.
Punter
Postby Dunny » Fri Nov 18, 2005 11:19 am
does that apply to silvertop AE101 also? Whats the factory setting for silvertop?
Dunny
Postby matt dunn » Sun Nov 20, 2005 9:50 pm
Yes both,
and both have 10 deg as factory from memory,
so set at 8 for NZ 96 or 98 fuel
Postby Dunny » Sun Nov 20, 2005 10:19 pm
great thanks - I'll give it a go
Dunny
