mauvis99 wrote:Ok sweet so at least its not only my car, has anyone found a solution?
matt dunn wrote:Kitrix wrote:and fresh out from a serviceKitrix wrote:my problem was it has no oil
mauvis99 wrote:So to get the ignition turned 2 degrees i have to get a mechanic to do it? cant i do it?
matt dunn wrote:mauvis99 wrote:Ok sweet so at least its not only my car, has anyone found a solution?
What ign timing is it set at.
Try 2 deg less than factory.
Dunny wrote:matt dunn wrote:mauvis99 wrote:Ok sweet so at least its not only my car, has anyone found a solution?
does that apply to silvertop AE101 also? Whats the factory setting for silvertop?
